Pellikan718 Pellikan718 is offline
Car: 2016 q50 3.0t
Default Strong Gas Smell from exhaust?? - 07-05-2020, 04:57 PM
2016 q50 3.0t 48k miles idk if mainly when ac on but usually gas smell from exhaustalso at 2 times it did almost stall and was hesitant when tried to gas hasnt done since but not sure anyone ??
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-06-2020, 06:21 AM
When at idle - take a look at your AFR and trim numbers for Bank1 and Bank2 - the AFR and Trim numbers from both banks should be very close to each other. IF however, the AFR number on Bank1 says 14.7 and Bank2 is noticeably lower - check the trim numbers for both banks. They too should be very close to each other. If not, you might want to take the car into the dealership and raise the concern of a leaking fuel injector.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM3.5s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
