keyap keyap is offline
Car: N55 135i
Default O-Rings For Pure High Flow Inlet - Where To Buy In The UK - 02-21-2016, 06:21 AM
So, the Pure high flow inlet got installed a few weeks ago and it's a great piece of kit with v high quality machining.
To maximise inlet area, the o-rings are quite thin and I've found will break if a little too much pressure is applied.
Jesse at Pure was good enough to confirm that the part no. on mcmaster.com is 9262K699 however, it's not really realistic outside of the USA to order from here.
If anyone in the UK needs the o-rings, which should be made of Buna-M (Nitrile Rubber), here's where to get a quality item at a reasonable price.
The size of the rings is 60mm ID and 2mm C/S
[B]
