boucherrmb boucherrmb is offline
Car: Infinit Q60 Red Sport
Default JB4 d sub pins - 06-04-2021, 05:19 AM
I broke one of the d sub pins off for the fuel wires when trying to slide it through the bushing and I ended up putting a little solder on the wire/sling it into the harness.
It held the wire in place and I was curious if this should be OK, or should I remove it/add a d sub pin to it?
If so, what size are the pins?
Default 06-04-2021, 08:53 AM
It's a standard male dsub pin (not high density).
Once inserted they can only be removed with a dsub pin removal tool. If it's making contact and fuel trims bank1/bank2 are moving in unison as fuel enrichment moves up then you're fine.
Default 06-04-2021, 09:47 PM
Thanks Terry and I did a couple mini pulls and it had 1 under Ďoptionsí so think Iím all good.
Iíll include the log for feedback
