threepedals threepedals is offline
Car: Veloster N
Default Just installed JB4 on Veloster N, please examine first log - 06-01-2021, 01:18 AM
I'm a log-reading newb, please examine and let me know if there's anything concerning here. Thanks!
2021 Veloster N 6-speed
HKS M45XL Spark Plugs gapped .022, no other performance mods yet
93 octane pump gas
MAP2 3rd gear
planning firmware update soon
File Type: csv P21_M2_R1_mtswithfrank_210531_151519.csv (9.6 KB, 34 views)
Default 06-01-2021, 09:10 AM
Looks fine so far to me!
Car: Veloster N
Default 06-01-2021, 09:25 AM
Thanks Terry!!! I really appreciate you checking it for me.
Car: Veloster N
Default 06-20-2021, 08:53 AM
I finally hooked up the fuel control wire on my Veloster N and got another log(attached).
Comparing to the first log I posted (above) AFR doesn't look any different but trim does. Can someone explain that please?
File Type: csv P21_M2_R1_afterfuelline_210619_174047.csv (11.3 KB, 15 views)
Chanluder's Avatar
Chanluder Chanluder is offline
Car: Stinger
Default 06-20-2021, 10:36 AM
You got some crappy corrections on this log.
Car: Veloster N
Default 06-21-2021, 02:31 AM
"Crappy corrections". Can you talk me through that a little bit? I assume you are talking about the ignition timing in the 0 - 4200 range?
What do I do about it? Should I remove the fuel wire? Terry said my first log (see above) looked OK, that was without the fuel wire.
Default 06-21-2021, 10:42 AM
You're pulling up to 4.5 degrees of timing...more octane usually resolves that.
Car: Veloster N
Default 06-21-2021, 12:13 PM
The car seemed OK on 93 until I connected the JB4 fuel wire. It makes less power and runs worse now. I'm kinda disappointed.
I have no plans to run octane boost or race gas so I guess I'll just disconnect the fuel wire. I really just want to get the most out of this JB4 on pump gas.
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 06-21-2021, 01:31 PM
Your not making less power your showing more boost. Try a reset disconnect the negative on the battery terminal wait 5 min and reconnect and re log. Then just keep an eye on it for awhile (re log in a couple days)
2020 Stinger GT1 AWD CERAMIC SILVER W/RED INTERIOR
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
LLUMAR STRATOS CERAMIC WINDOW TINT
STEK DYNOSHIELD FULL FRONT CLEAR BRA
CERAMIC PRO SILVER PACKAGE
OEM PUDDLE LIGHTS INSTALLED AFTERMARKET
OEM FRONT AND REAR SPLASH GUARDS
DRONE MOBILE REMOTE START
Car: Veloster N
Default 06-22-2021, 02:53 AM
True, it shows a bit more boost but timing is down by 4.5 degrees and I can easily feel the power loss. If I enable bit 0, it feels noticeably better and the timing comes back up.
I had disconnected the battery when I connected the fuel wire. So I guess I'll just drive it a little more and get another log as you suggested.
Thanks everyone for your feedback, I do appreciate it!
Car: Veloster N
Default 06-24-2021, 04:59 AM
I have driven the car a little more, and have taken more logs. Here's graphs for ease of comparison, I can also provide full logs.
First, here is comparison between fuel wire connected and no fuel wire connected:
levels and timing back up.
Car: Veloster N
Default 06-24-2021, 05:00 AM
Here are two more pulls, one in 3rd and one including 1st,2nd,3rd gear. Each of these graphs is on the same 93 octane pump gas, no fill-ups in between.
Looks dramatically different all of a sudden. Is this thing learning or is there some other explanation?
The 3rd gear pull shows increased boost over no-fuel wire condition and better timing than the first graph above.
The 1-2-3 pull shows boost back down to no-fuel wire levels and timing back up.
