(#626)
KjKeyz KjKeyz is offline
Car: 335XI 08'
Default 05-28-2021, 07:15 AM
I'm finishing up my turbo install of some RB 2+, I have done everything in the first post for starters. I'll be running 93 octane (hard to find E85 here).
I saw Terry mention a version 36 and upgrading to T3? I have version G5_ISO_32_14 on my JB4. Can someone clear this up for me?
2008 335xi | JB4 | VRSF Charge pipe | VRSF 7in. HD intercooler | VSRF Aluminum Outlets | VRSF Down P!pes | RB silicone inlets | BMS Dual cone intake | Turbosmart Kompact Dual Port BOV | RB PVC valve | OCC | RB 2+ Turbos
jiriarte's Avatar
jiriarte jiriarte is offline
Car: e92 N54 RACE CAR
Default 06-03-2021, 11:42 AM
Hi guys, first of all I introduce myself, it is my first post in the forum, my name is Jorge and I am from Chile, I have been working with BMW for 12 years and for 2 years we have been building a project for a track. an e92 n54 hybrid mamba 14t turbos, inlets, ********, fmic 7.5, lfp stage 2, we have solved all the problems and now we are improving the map, I have mhd and jb4, I'll leave today's log to see what you can tell me. I currently run map 6
https://***********/u/jiriarte/log-1...8-3-9-11-18-20
<a href="https://ibb.co/8zFJTGZ"><img src="https://i.ibb.co/8zFJTGZ/Captura-de-Pantalla-2021-06-03-a-la-s-14-04-12.png" alt="Captura-de-Pantalla-2021-06-03-a-la-s-14-04-12" border="0"></a>
Car: 2008 E93
Default 06-04-2021, 12:09 AM
Csv ?
Donde en Chile ?
jiriarte's Avatar
Default 06-04-2021, 04:37 AM
Originally Posted by THE BEAST
Csv ?
Donde en Chile ?
si chile . santiago
Car: 2008 E93
Default 06-04-2021, 08:50 AM
si chile . santiago
Need CSV file.
jiriarte's Avatar
Default 06-04-2021, 09:02 AM
Need CSV file.
It's very big, it won't let me upload it and I don't know how to make it smaller
Default 06-07-2021, 01:40 PM
You're on v14. The latest v15 and v16 are in the app. V16 has user defined maps 6/7/8 but remains experimental, we've had a couple reports of settings scrambling still. Although I haven't been able to recreate it here. So if you're going to run it take advantage of the apps feature to save settings to file so you have a backup.
Car: 2008 E93
Default 06-07-2021, 07:23 PM
Loaded it up again a couple days ago.
Still scrambles maps around after power on / off. I let the car sit, went in to eat, came back out and stuff scrambled.
Also did a cold start and its MUCH louder just as I had told you via email that car would drone in 6th on the frwy which it never does on other firmware.
I did not bother driving it after all that so I reverted again.
SAVINM SAVINM is offline
Car: bmw 335i n54
Default 06-07-2021, 07:57 PM
Terry, please look into this issue. Looks like I not the only one having the same problem.
Car: 2008 E93
Default 06-07-2021, 08:15 PM
What are you experiencing ?
Car: bmw 335i n54
Default 06-07-2021, 08:58 PM
Everytime when I switch the car off, the duty bias settings get reset. I have to reload everything again.
Car: 2008 E93
Default 06-07-2021, 09:04 PM
Mine used to do all that on T1.
Then that got fixed but my car drones on BETA firmware and maps change around. Say I do 20 psi on map 6, and 23 on map 7 and 26 on map 8...ill log say map 7, but will reflect boost curve of map 6. The log will clearly show map7 but record the settings of another map.
Any of this happen to you ?
Oh and base wgdc will jump around at times.
Car: bmw 335i n54
Default 06-08-2021, 12:40 PM
Sorry for the late reply. I only use map 3 on my JB4. Have not tried the other maps on this new firmware. Once I experienced the issue with the duty bias settings being reset continuously, I reverted back to my previous firmware.
Car: 2008 E93
Default 06-08-2021, 12:44 PM
Hopefully it gets sorted out soon.
Car: 2008 E93
Default 06-09-2021, 11:18 AM
I wonder if maybe the jb4 mobile glitches things. You say you have not been able to recreate it. Are you using laptop to save settings ? Might be worthwhile to ask people how they are saving settings.
I, for one, am using Jb4 mobile app and have these issues.
Car: bmw 335i n54
Default 06-09-2021, 11:35 AM
I also use the JB4 mobile app.
Car: 2008 E93
Default 06-09-2021, 01:34 PM
Now we need more people to chime in and see if its the way settings are being set, or firmware issue.
I know jb4 mobile glitches switching maps on new firmware. I click map 7 from map 6 to set it up and I have to click twice because it stays on map 6. Sometimes I have to click 3x, sometimes one click and it changes over. I showed Terry this as well.
Hopefully all this info and if we can gather more, will help to solve these issues.
Stevae's Avatar
Stevae Stevae is offline
Car: 2009 BMW 335i E92
Default 06-09-2021, 04:18 PM
I'm also using the JB4 mobile app, and my duty cycle and boost's are being reset to zero.
2009 E92 335i: M-Performance exhaust, VRSF ***less DP's & upgraded inlets/outlets, Upgraded Turbos Hexon RR600s, VRSF 7.5" FMIC, aluminum Charge Pipe; Forged aluminum Diverter Valves w upgraded Yellow Springs, Walbro 450 LPFP, Spec Stage 3+ clutch w SMFW, Custom welded RB external PVC w ported & polished heads from Motiv, 3.5 Bar TMAP, BMS dual OCC's, BMS cowl delete & DCI's, Index 12 Fuel injectors, M3 suspension, KW v3 coilovers. JB4 G5 &/or MHD custom tune by Jake from Motiv Motorsports.
Car: 2008 E93
Default 06-09-2021, 05:50 PM
Interesting how for some its, dutycycle, boost, base wgdc, etc...seems like it varies from one person to another.
Is there anyone other than Terry on Beta that has zero issues ?
If so, what was used ?
Jb4 mobile or laptop ?
Btw, anyone else have a loud exhaust ? As mentioned before, on Beta my car drones, but once I revert, all is well again. I would imagine this may not be noticeable to anyone on stockish exhaust., on custom exhaust its VERY noticeable.
temperamental's Avatar
temperamental temperamental is offline
Default 06-10-2021, 11:05 AM
I experience the same issues as per the above posters. My exhaust is unusually loud as well on the new firmware.
Decided to revert to the older firmware until issues are resolved.
JB4 Flex Fuel //MMP Stage 3 turbos//Custom Exhaust/BMS DCI//FMIC/KW suspension//Fuel-it Pi & Fuel it stage 4/BMS OCC's and too much to mention
Car: 2008 E93
Default 06-10-2021, 03:21 PM
Thank you !
So its not just my car that got louder on Beta firmware !
Car: 335XI 08'
Default 06-11-2021, 12:07 PM
Thanks for the reply. I have had this happen to me as well with the settings not saving (even though I'm not on the newest firmware). I use the JB4 app on Android.
Stevae's Avatar
Default 06-15-2021, 04:08 AM
Is there any updated information on a fix? Thanks.
Car: 2008 E93
Default 06-15-2021, 11:53 AM
Not yet.
Terry.....
I would be happy to leave PI algorithm as is and just add 1 more user adjustable map (6).
Also not much need for for 3 user adjustable AND the ability to save different duty bias, fuel bias, etc.
The JB4 adapts from all maps as it is.
This may help simplify things to get the firmware going.
n1kson n1kson is offline
Default 06-15-2021, 01:16 PM
Hi Terry,
Please take a look on my log, i have 500cc on chargepipe and 6x250cc pi. Im on 98 pump fuel and im using backend hybrid e85 map on which i lowered timing. Problem is that my trims are playing on high rpm and fuelEN is always different on all pulls. Is JB4 adjusting meth flow itself and don't looks to my fuel bias? In this log there is 3 pulls in 3rd gear in 2-3 minutes. How can i get softer trim changes? And also, trims are in ~40 when spooling, how can i reduce that? Thanks in advance
