Gjohnson7771 Gjohnson7771 is offline
Car: 2011 BMW 535i
Default Log Review: F10 N55 - Map 5 - 91 Oct - 08-24-2020, 09:12 PM
Hello guys. I just installed a pre-owned JB4 on Friday and I am trying to get the hang of reviewing these logs. Can someone please let me know how these look and if there are any settings I need to adjust?
2011 535i N55 PWG roughly 139k miles
- Chargepipe
- 91 octane
- Eldor Ignition coils - Installed in June
- Stock Bosch Spark plugs - Installed in August of 2019 roughly 8,000 miles
Default 08-25-2020, 04:17 PM
Runs look pretty good to me. I'd change FF to 100, duty bias to 30 across the board, to speed up the WGDC adaption process.
Car: 2011 BMW 535i
Default 08-25-2020, 05:43 PM
So, it you don't think I have anything to worry about? I was looking over the logs with a friend and we thought the Ignition timing looked like the DME was retarding the timing pretty bad.
Also, it looks like in the the Third Gear Manual Sport + log the engine over boosted pretty good. Is that normal? Sorry, I am learning.
Attached is another log, but on Map 2. I got scared after looking at the logs yesterday and the timing.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
Jb4 w/ MHD RACE BEF, RVG DP, Car Labs CP, Walbro 455HP LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC Coming soon: 6wb Cluster..........
Default 08-26-2020, 06:57 AM
I see the drop in timing around the 5k mark.
Still just 91 octane?
After setting & map changes, it does take a few WOT adaptation pulls for things to start to fall in line.
likely smooth the boost curve out with some duty bias tuning & the timing drops, in most users cases is due to lack of octane, or tired plugs. I'd assume based on your modifications the timing corrections are stemming from the 91 octane fuel.
Car: 2011 BMW 535i
Default 08-26-2020, 07:37 AM
Ok, so would you recommend going back to Map 5 and adjusting the duty bias and FF?
Yes, I am still only running the 91 octane. I plane to add some E85 at the next fill up. Planing on a E30 blend.
Also, can you please advise what I should expect to see in Ignition Timing numbers?
Should I be concerned with the Over boost that occurred?
My plugs aren't crazy old, but I plan to upgrade them to 1 step colder NGK's as soon as possible.
Car: 2011 BMW 535i
Default 08-26-2020, 08:10 AM
Attached are my current User Settings. Please let me know if you notice anything else that needs to be adjusted.
Default 08-26-2020, 12:45 PM
I think you can stick to map 1 or 2.
Manually lower your FF from 150, down to 70
I’d try adding a gallon of 85 to your current tank (assuming you aren’t on e) and relog map 2
Car: 2011 BMW 535i
Default 08-26-2020, 02:37 PM
Ok, I will make some changes and re-log as soon as possible.
Car: 2011 BMW 535i
Default 08-26-2020, 07:30 PM
Ok, made the changes recommended above and got a quick log. FYI, apparently my jb4 app was setup to combine the logs, so the first wot is in comfort mode and the second wot is Sport +.
File Type: csv map2 91 oct comfort & sport combined log.csv (10.1 KB, 179 views)
Default 08-28-2020, 07:35 AM
So for future only log in sport + with traction fully off.
Duty bias settings, those look really off- set those to default & relog in sport+
Car: 2011 BMW 535i
Default 08-28-2020, 08:56 AM
Thanks for the info. I will make sure to log in Sport + only.
As far as the Duty bias is concerned. In the post above, Terry has suggested to change Duty bias to 30 across the board. Was that incorrect or was that only for Map 5?
Default 08-30-2020, 06:57 AM
30 works, but I think i saw some values like 29 or something in there.
At any rate, double check them, ensure all at 30 & relog
Car: 2011 BMW 535i
Default 08-31-2020, 03:28 PM
Ok, hereís a new log on E30. I double checked and all my duty bias are set to 30 and I did a few wot pulls before this log. Log is on Map 5.
Default 08-31-2020, 10:05 PM
overboosting a bit on tip in & timing doesn't look that great, drops across multiple cylinders.
How sure are you that your mix is e30? Did you measure the content at the pump?
Car: 2011 BMW 535i
Default 09-01-2020, 05:54 AM
Well, it looks like we will have to try the review again in a few days. I just downloaded a new, more detailed E85 calculator and it looks like I am only running around E15 at the moment.
Default 09-01-2020, 01:45 PM
Okay, thatís not necessarily a bad thing, as that now tells me why timing didnít look great.
Letís get your content up to e25-30 range & see if that timing cleans up
Car: 2011 BMW 535i
Default 09-06-2020, 06:31 PM
Ok, attached is an updated log with E-85. I should now be close to a E30 blend. I can definitely see on the logs that my IAT’s are really creeping up. Looks like the FMIC is moving up the priority list. Well atleast we have a cool front coming in next week, temps are supposed to drop from the 90’s to low 70’s.
Default 09-09-2020, 07:33 PM
This looks overall decent
Cyl 5 lags a bit, but that is usually always a noisy cyl.
How does the car feel?
Car: 2011 BMW 535i
Default 09-09-2020, 07:50 PM
The car feels good and strong. Honestly, I'm not sure what to expect though. My last car build was a LS swapped 240sx which had I completely different feel to the power band.
Currently, I plan to upgrade to a FMIC, but I'm not sure if there is anything else I should be considering as a priority.
Default 09-11-2020, 05:11 PM
I am assuming a very linear/ flat powerband on the LS swapped 240?
I'd for sure upgrade the FMIC, as the IAT's creeping up isn't helping timing.
Car: 2011 BMW 535i
Default 04-02-2021, 11:46 AM
Hey guys. I just installed my FMIC and I did a few pulls for review. Since the previous logs I am now running a new Walbro 450lp fuel pump and FMIC. I am still on stock Bosch Spark plugs, so I think I will be adding the NGK 1 step colder plugs to my list. All pulls where done in Sport +, with one pull on paddle shifters. Running a E30 Blend.
Default 04-05-2021, 10:40 AM
Looks normal, just some minor timing corrections.
Car: 2011 BMW 535i
Default 05-12-2021, 07:12 AM
Ok, updated logs with new mods. I just added the MHD BEF, currently running the PWG1_E85 Tune with JB4 on Map 7. The car feels really strong on day to day driving, however when I attempt a WOT pull for logging I'm not hitting my normal boost. I have uploaded 3 logs for review. The 1st is just a typical driving log and you can see at about 70% throttle, I hit around 21psi. On the other 2 logs, I am in Sport+ mode and ready to log, however my peak boost is around 16 psi. Does it look like I am having a fuel issue?
I am running the Stage 2 walbro 450 lpfp and roughly a E35 blend on these logs.
Default 05-12-2021, 09:52 AM
Please upload proper logs....
Logs that aren't WOT or are in 2nd gear with tires spinning etc. are a waste of time.
For proper review and the JB4 to adapt, please do logs in 3rd or 4th gear from 2K rpms to redline at wide open throttle.
Car: 2011 BMW 535i
Default 05-12-2021, 10:04 AM
The 2nd two logs uploaded are WOT, started in 3rd gear at 2k rpms in Sport+.
Roughly 25 mph rolling start, until around 90 mph.
It does look like the transmission downshifted at the beginning of each log. I can try to log again in Manual mode if that's better.
