RVA_N55_Fan RVA_N55_Fan is offline
Car: 2014 435i
Default 10-23-2021, 10:00 AM
Ordered new eldor coils and going to gap at .020
Car: 2014 435i
Default 10-23-2021, 10:19 AM
Unplugged my maf...nice change on its own...smoothed idle out a bit
Car: 2014 435i
Default 10-23-2021, 01:12 PM
Can you clean the female side of a tmap connector? YouTube ain't helping. Since the 3.5tmap I bought new from bms, guessing that doesn't need cleaning.
Car: 2014 435i
Default 10-28-2021, 03:11 PM
Installing tmrw night. Will log and post. 🤞
Car: 2014 435i
Default 10-30-2021, 09:43 AM
Finally got plugs gapped and coils installed. See logs for review please.
No codes. Tire spin in 3rd on last pull (if I remember correctly)
435gc 435gc is offline
Default 10-30-2021, 12:31 PM
What fuel are you using again?
Car: 2014 435i
Default 10-30-2021, 12:32 PM
This was on 100oct.
Car: 2014 435i
Default 10-30-2021, 12:34 PM
Tanks almost empty and will try 5 gallons of e85 next.
Jb4 BEF f_ewg_ps2_Race
Car: 2014 435i
Default 10-30-2021, 12:36 PM
Also, MAF plugged back in...tired if the engine light staying on.
Car: 2014 435i
Default 10-30-2021, 12:55 PM
Final log on 100oct. Getting e85 now.
Car: Evo VIII
Default 11-01-2021, 07:37 AM
Your FOL is at 0. Try setting everything back to default settings and upload a log again.
Car: 2014 435i
Default 11-01-2021, 05:19 PM
Not my best log pulls...but might be worth taking a look at...looks like trims are better now.
Car: 2014 435i
Default 11-01-2021, 07:58 PM
The default screenshot for n55 big turbos has fol set to 0. What am I missing?
Car: 2014 435i
Default 11-05-2021, 01:58 PM
Update: Upgraded lpfp to Walbro 535. DIY
I'll post logs when I get the chance to run this weekend.
Car: 2014 435i
Default 11-05-2021, 03:42 PM
Attached the spool hpfp install guide they just sent me..also the spool ships with 2 adapters I validated you only need 1.
File Type: zip BMW 335 (N55) FX-150 Install Guide.pptx (1).zip (7.76 MB, 12 views)
Car: 2014 435i
Default 11-06-2021, 04:09 PM
Not sure if this give you enough info but only log I have that shows this issue.
Row 12 wgdc pegs to 99
Row 16-22 throws code 120308 (boost pressure lower than expected)
Happens in 3rd gear as well...just didn't have mobile app connected as I wasn't trying to do logging at that time.
Also Row 20 throttle drops to 76 (seems odd)
Thoughts? (Promise I'll have legit logs asap)
Car: 2014 435i
Default 11-07-2021, 12:40 PM
Map 2 and 7 logs (3rd gear WOT)
Thru the 120308 code on the map 7 pull but after it throws it it doesn't seem to have much impact.
Prior to these pulls had the dme torque code (sucks as it jerks the hell out of you). I did realize I had sport + on when it thru this code rather than dsc off. Could that relate to this issue?
Look forward to your input.
Daniel
Car: 2014 435i
Default 11-07-2021, 12:55 PM
I'm on the f_EWG_19_T3 firmware...beta. any concerns being on this version?
Car: 2014 435i
Default 11-15-2021, 07:56 PM
As for an update:
Boost pressure test at 24psi wo any issues found
Reverted back to the most current firmware.
Add colder ngk step 2 plugs gap .020
Changed from Bosch to eldor coils
Map 2 no issues
Map 7 w e30 no issues
Map 6 w eXX in progress
Working w an awesome guy from this forum w similar setup to figure out map 6 tune capabilities on different eXX levels. He's been a huge help.
Only code I occasionally get is boost pressure lower than expected. Only thing I can figure is the bov instead of dv+ is causing some calculation error. Code doesn't cause any issue re map switch or power loss.
Summary: hpfp, lpfp, and PS2 have started to finally produce results. Unclear what resolved tmap codes either reverting to stable firmware or upgrading lpfp (not sure if those even have impact but since completed no tmap codes)
Ending posts. Maybe info shared helps another on a similar path.
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
