OldBooster's Avatar
Car: 2008 135i AT
Default INPA software - 01-14-2016, 09:05 AM
Where do I get/download INPA software so I can code an injector? Many, MANY thanks. Larry
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
steve.kodra steve.kodra is offline
IXLR8
Default 01-14-2016, 09:50 AM
PM me.
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 01-16-2016, 07:59 PM
Just coded my new injectors. Have INPA here, if you still need it pm me
07 335i e92 - money pit
Default 01-17-2016, 10:59 AM
Can't upload the files now, but I downloaded the files from this website
http://ncs-expert.com/downloads
Download both files
INPA-6.4.3 – Download
INPA-5.02 – Download
and follow these instructions
http://www.bimmerforums.co.uk/forum/...64bit-t103023/
pdcnc's Avatar
pdcnc pdcnc is offline
Car: BMW 335I
Default 01-22-2016, 03:30 PM
This tutorial also serves to Windows 10 ?
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 01-22-2016, 04:45 PM
If your tech savvy, check out my DIY:
DIY: How to setup BMW Standard Tools 2.12 w/Windows 10 x64 (64-bit)
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
Default 01-22-2016, 11:27 PM
Download both files
I ended up downloading everything and following steps and my windows 10 will not open the extracted files. Wth is going on!
2007 e90 335i
Hexon turbos
Fbo with Cpi tuned at e55
Jsr Custom tuned
Car: 2010 135i
Default 01-22-2016, 11:40 PM
Go back through the entire How-To ...
nearing the end there is mention of 7-zip being the needed program.
http://www.7-zip.org/
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-24-2016, 01:37 PM
As the guys talking a pure Inpa,
Downloaded my Inpa on Windows vm and seems to run fine, just one strange thing as I wanted to test my injector coding after I open the injector page I get only page showing f1 injector 1, f2 injector 2.... Etc but it doesn't show the existing injector values bar, it just popup to enter new values...
Is it an issue with Inpa or I'm missing something? My car runs fine and I don't really to code injectors I'm just browsing through the options only.
If the injectors not coded there also should be the values bar of the injector regardless correct?
Default 01-26-2016, 09:58 AM
Had similar problem. INPA connected and everything but it wouldn't show the injectior bar like on the YouTube video.
I closed all the programs,removed the cable from car and computer. Turned the car off removed the car. Then turned the key on, connected the cable to the car and computer, opened INPA and this time it worked.. It showed the bar with green marks and the current values. As I changed the values the green bar would change with it.
krisnicastro krisnicastro is offline
Car: 2008 bmw 335i
Default help - 06-01-2016, 02:46 PM
inpa will not load up injector option. When i go into system diagnosis all bars on bottom of page are blank and nothing shows on the right side of the screen. I need to code injectors asap, please help!!!
windows xp 32 bit
geprgy22 geprgy22 is offline
Car: M5
Default 10-10-2016, 12:15 PM
dead links for INPA ?
Anybody have some links to download ?
Download both files
Frozz's Avatar
Frozz Frozz is offline
Default 10-10-2016, 10:28 PM
following
Stroked & Blown Stroked & Blown is offline
Car: '10 e61 535i Xdrive
Default 10-11-2016, 04:37 AM
This is probably the easiest - you just need to install VMware player, adjust COM port, and code: http://www.e90post.com/forums/showthread.php?t=1220039
BLKMAGIC BLKMAGIC is offline
Car: 2010 335i
Default 05-30-2017, 01:40 AM
I need a version INPA that works, anybody have one?
2010 335i M Sport
JB4/G5, ***, Intercooler, DCI, 19s,
marcus510's Avatar
marcus510 marcus510 is offline
Car: BMW 2009 335i
Default 05-30-2017, 02:19 AM
check pms
2009 335i | N54 | JB4 | MHD | DOC RACE 6266BB |
Car: 08 535i
Default 05-30-2017, 08:26 PM
I am new to the n54 platform and want the ability to code and fix my car. Is this what I need along with a BT cable? I am new to this so thank you.
Jp335 Jp335 is offline
Car: 2008 335
Default 06-15-2017, 05:47 PM
I need a working copy of inpa 5.0.2 for xp as everything i have tried doesn't work.......
HELP PLEASE
Car: 2008 E93
Default 08-18-2017, 05:55 PM
Easiest way to code injectors ???
Car: 2008 E93
Default 08-18-2017, 05:56 PM
I have MHD , xHP, and the cable works for both. So do I just need inpa ? Or is there another way ??
