(#1676)
harizbbjt harizbbjt is offline
Car: Bmw F10 520i
Default 10-12-2018, 05:41 PM
Does it happen on map 0?
yes it does but when I disconnect the jb4 everything is fine.
vkiyko vkiyko is offline
Car: BMW F30 328I 2012
Default 10-16-2018, 03:32 AM
I have the POSI-TAP connectors JB4 N20
my friend have updated my JB4 to the OBD version of firmware. Now I cant use my JB4 properly.
I can't read logs neither on PC nor via Bluetooth.
Where can I get an older version ? for JB4 without OBDII
Default 10-16-2018, 07:45 AM
You can't. You'll need to convert it to new OBD style. You can find it here:
http://www.burgertuning.com/JB4_upgrades.html
It will be labeled as :
OBDII CABLE WITH JB4 SIDE CONNECTOR FOR RETROFIT
Default 10-16-2018, 07:47 AM
Can you email me, it will be easier to help you on this.
Payam@burgertuning.com
Default 10-16-2018, 07:50 AM
Thank you for the prompt reply.
However, I am Located in Russia. Delivery would take around a month.
Is there any other way of reconnection of existing wires for my JB4 to work?
