(#551)
schand820 schand820 is offline
Car: B9 S4
Default 06-01-2019, 08:08 AM
Just curious has anyone been able to get any numbers on the s4 running map? What's the increase to hp etc. I'm thinking of taking mine for dyno but was curious to see if anyone has any numbers. Btw I'm running map 3 with 91 octane.
skyseer skyseer is offline
Car: gtr
Default 06-03-2019, 02:13 AM
RS4/5 with JB4 on 93 will run around a 11.3@119mph. I think the GTR is slightly quicker than this?
Ok, thx. My best time on completely stock gtr was 11.2 (on good gas).
Aus1 Aus1 is offline
Car: Golf R
Default 06-03-2019, 04:01 AM
Originally Posted by kanemari
has anyone with a right hand drive s4 managed to do a hidden install for the obcd wiring from the engine bay to the ****pit? i can't for the life of me find the rubber plugs to pierce and pass the wire through... i did the quick version along the inside of the door so far but want the cleaner option.
You manage to work this out? Just installed on SQ. There is a rubber plug just above the brake pedal. Let me know if you need some photos
Pietia Pietia is offline
Car: S4 B9
Default 06-08-2019, 10:39 AM
Hello guys! I installed jb4 in my s4b9 with BC nad BT. I still have got The old version JB4 mobile on my phone because I had jb4 in my golf 7R which i sold. The problem is when i First start jb4 on audi i forgot and connected the box with the mobile with firmware from golf 7 r. When i realized that i should install firmware i did it. When i turn on the mobile with right firmware everything seems ok but i dont feel any increase od power. Any suggestions? I used map 1,2,3 and the results are like stock yet :-(
The jb4 in golf 7R worked excellent and after golf I need more power in audi :-)
Default 06-08-2019, 10:52 AM
Don't see the JB4 log attached to your post.
Car: S4 B9
Default 06-08-2019, 12:36 PM
Here you have. Scroll down and push green rectangle (Pobierz Teraz). Dont worry any virus :-) If any problem I can send on email, whatsup, etc.
Darmowy hosting plik√≥w - wrzucaj i dziel siń™ plikami za darmo | 2019-06-08 21_06_34_Map-1.csv
Default 06-08-2019, 01:26 PM
As per email I sent you need to populate your settings first with the BCM settings in post 1.
The S4_4_T4.hex is the newest version so load that.
