Z_god203 Z_god203 is offline
Car: E70 X5 50i
Thumbs down E70 - 07-16-2021, 12:46 PM
Not for nothing half of the the things you guys advertise you can do you canít literally all you can do is change the map other wise you canít read codes canít clear codes. Half of the reading displays donít work. The passive delete doesnít work cause it canít read the codes. Thereís no way burger doesnít have anything it canít be that much different if I knew you couldnít do half the stuff I wouldnít have wasted the money. And every time you look for help the answe is we donít have anything ?
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 07-16-2021, 02:57 PM
Most of those issues are related to the platform. The E70 is OLD. If it doesnít report stuff, the JB4 canít read it. Not to mention that the E70 has the original N63, which is a ticking time bomb. None of the tuners want to go very far with it because of that. Passive delete none of us have on any platforms. Commiefornia ruined that for us.
Mike Levy
Car: E70 X5 50i
Default 07-17-2021, 05:26 PM
I get that itís a old platform and Iím not asking for different maps Iím asking for it to do what they say it does. Allís Iím saying is how can you sell something and advertise it but it doesnít support everything. At least other companies like bootmod heat it real and was like no we donít have anything or offer it
SR1975 SR1975 is offline
Car: BMW X5 50i
Default 07-20-2021, 01:02 AM
Terry did get back to our platform and updated the firmware so you can have map 6 again Plus nearly all of the gauges now work. There are five different firmwares listed that will work with the E70/N63, The best of the bunch is by far the JB4_P62_X5N63_1_T3.hex so make sure you have that loaded.
I also recommend you contact ESS tuning and grab their tune. I am running their stage 2 + map3 (still playing with map6) for around 18-20psi boost. My near 10 year old 170k+ mile X5 is busting out sub 4 second 0-60 times, on par with a X5M. People can Say what they want about the N63, when its tuned its awesome and makes your X5 an amazing sleeper. Little clip below of just messing around with map3.
BMW X5 N63 Prototype Intake Test - YouTube
Car: E70 X5 50i
Default 07-20-2021, 07:28 AM
I’ll look into the Ess tune. Did they ever get it to read codes?
Car: BMW X5 50i
Default 07-20-2021, 01:08 PM
Definitely get the Ess tune, no more engine codes with it.
JB4 still won't read codes, get the foxwell nt510 or higher with the BMW software on it. Works excellent with the E70. Another option is installing ISTA on a laptop and grabbing a DCAN cable. Allows you to do absolutely everything the dealer can. I use both the foxwell or ISTA depending on what I'm doing.
Third option is bimmergeeks protools and a DCAN cable. This allows advanced coding options too. For example I used it to code my rear hatch to close softly instead of slamming and coded to accept LED fog lamps.
Car: E70 X5 50i
Default 07-20-2021, 02:12 PM
Iíll look in to the bimmer geeks I have snap on and Matco scanners that read fine it was just the convience of having it on the fly with the jb4 appreciate the insight on the coding
Car: E70 X5 50i
Default Update - 07-20-2021, 02:33 PM
So today is the first real day I sat down and messed with the jb4 for more than 20 mins and so I got it to read codes and I got the passive delete to work. No more cel light 🤩
mrfiander3212's Avatar
mrfiander3212 mrfiander3212 is offline
Car: X5 xdrive50i
Default 07-20-2021, 02:56 PM
What is passive delete
Car: E70 X5 50i
Default 07-20-2021, 03:23 PM
so im running *** and have constant 02 sensor code, thru passive delete i was able to have the cel off
Mike_L's Avatar
Anti-Social
Default 07-20-2021, 04:16 PM
Get a pair of ************************************* I always run the mini k@t ones, just in case. Those will ************because the sensors will see the right readings.
Edited: Do not post how to bypass emissions or your posts will be deleted.
Mike Levy
Car: X5 xdrive50i
Default 07-23-2021, 06:18 AM
how do i check this setting cant seem to find it.
Default 07-23-2021, 03:24 PM
Passive delete is under the WMI setup screen.
Car: X5 xdrive50i
Default 07-29-2021, 02:21 PM
How do i turn active sound off cant find the setting
Mike_L's Avatar
Anti-Social
Default 07-29-2021, 04:35 PM
Got do it in E-SYS. Thats coding, not tuning.
Mike Levy
