WinfnitiQ50 WinfnitiQ50 is offline
Car: Q50
Default Help with log - 11-04-2020, 02:10 PM
So I was trying flex my jb4 a bit and show a friend the difference it has on my q......well for the first time ever my jb4 didn't do ****....boost stayed a peak 8-9lbs no matter what map I'm on...when looking at the graph there is no blue boost override its perfectly in sync with my ecu psi....any idea whats causing this?
Default 11-04-2020, 02:13 PM
Would need a CSV log for any tuning advice.
Car: Q50
Default 11-04-2020, 02:37 PM
okay here is full log. This was map 6...max boost 8 psi over stock
Car: Q50
Default 11-04-2020, 02:39 PM
Here is map 4
Default 11-04-2020, 02:54 PM
That's a PDF, not the CSV from the JB4 app.
Car: Q50
Default 11-04-2020, 03:08 PM
Sorry I thought it had the same info...attached is the CSV, this was Map 4 and my map 6 looks quite similar yet has a higher peak boost set that I have seen before now it just spikes to 13lbs or greater between shifts and thats it stays strong at 9lbs lol
Default 11-04-2020, 05:19 PM
That is not a valid CSV file for some reason. You can email the log directly out of the app to yourself then save it here that way. Or if you want support via email then send it along with details to support@burgertuning.com
