Jineric Jineric is offline
Car: E92 335i
Default Question for 335i owners with M3 control arms - SOLVED - 11-07-2019, 01:08 PM
Hi all,
I have recently upgraded to the front M3 control arms, alignment done after installation.
Lately when I hit certain humps, the front passenger side tire will rub the fender. Was wondering if any of you had the same issue?
I am running KW coilovers and didn't have any issue before the upgrade.
Could it be an alignment issue? or bad installation of the arms?
Car: E92 335i
Default Solved - 11-11-2019, 10:00 AM
Issue resolved. Was due to bad alignment.
Went to do another alignment and tried going past the usual bumps, no more rubbing of fender. =)
THE BEAST's Avatar
Car: 2008 E93
Default 11-24-2019, 05:32 PM
Was the alignment "off", or did the second alignment adjust for it to not rub and now its actually off a bit ???
