GETAMBUSHED GETAMBUSHED is offline
Car: 2021 Veloster N (MT)
Default Veloster N Mild Custom Map - 09-24-2021, 08:29 AM
is this safe or do I need a custom map that runs slightly less boost then Map1?
Im using 93 Octane but not sure if Map 1 is safe based on my log. I think everything looks ok except for maybe the ign? Is it supposed to drop like that?
Would trying a different brand of gas possiblly help change that?
Any advice would be appreciated
Default 09-24-2021, 09:09 AM
Picture of the log
Slo3.3TT Slo3.3TT is offline
Car: 2022 Kia Stinger GT1
Default 09-24-2021, 03:32 PM
Are you running stock plugs?
Default 09-24-2021, 04:21 PM
No running the HKS plugs
Default 09-24-2021, 04:29 PM
when I look at all the ignition only the one looks like that
Default 09-24-2021, 06:21 PM
What did you gap them at?
Default 09-24-2021, 06:23 PM
they were set at 024
Default 09-25-2021, 03:42 PM
Maybe try a bit of octane booster so see if those timing corrections go away. They're not too bad but could improve.
Default 09-25-2021, 04:03 PM
Default 09-25-2021, 04:05 PM
So I am looking for the ignition2,3 and 4 numbers to go to zero or close to zero correct?
Default 09-25-2021, 05:26 PM
Correct
Default 09-25-2021, 05:43 PM
Ok that helps, Now I know what Im looking to adjust
Default 09-26-2021, 07:03 AM
Im going to try different brands of gas to see if I can improve this but as it is, is it safe? Can this hurt my engine? Sorry for the questions just new to this and don't want to cause any damage. Would disabling the fuel wire help this this?
Default 09-26-2021, 10:57 AM
I did a map 0 pull and a map 1 pull and they almost look the same as far as the ign#'s.
Default 09-26-2021, 03:29 PM
Which of these is correct for a Veloster N, I have seen people do it both ways?
Default 09-27-2021, 11:39 AM
The charge pipe gets the rainbow patch and the manifold gets the black and brown patch.
Default 09-27-2021, 11:46 AM
So its the picture on the right then. Andro at Burger sent me the picture on the left which is from the video link on the burger site and the other picture is from the install link on Burger site showing the opposite. So confusing. I will switch it. Could that have something to do with the timing pull?
Default Log Check - 09-27-2021, 01:01 PM
Hi Steve
Can you tell me how this log looks, this is after I switched the wire harnesses around to what you said. (Brown up top, colored harness on the charge pipe.
thanks
Default 09-28-2021, 01:39 PM
No, that wouldn't have anything to do with timing being pulled. One Map sensor has a temp sensor and the other doesn't.
I'd suggest doing proper logs for review but yes, you still have some timing corrections. They're not horrible but I'd definitely recommend sticking with map 1.
Default 09-28-2021, 01:50 PM
Im ok with Map 1 if thats whats safe, I will try and get a full log after I can fill the tank with a different fuel
thanks for your help
