GETAMBUSHED GETAMBUSHED is offline
Car: 2021 Veloster N (MT)
Default Log Check - 09-23-2021, 09:54 AM
3rd gear pull Veloster N 93 Octane Map 1
Default 09-23-2021, 12:59 PM
Looks pretty normal...with that fuel, I'd stick with map 1.
Default 09-23-2021, 01:07 PM
The fuel is 93 Octane, Andro from support at Burger told me I could go to map 2? What do you see that makes you say map 1? And what would I need to change for me to be able to use map 2?
Slo3.3TT Slo3.3TT is offline
Car: 2022 Kia Stinger GT1
Default 09-23-2021, 01:39 PM
The fuel you're running can't support map 2 safely. The moment you start the run you start dropping timing and it gets worse the higher the engine rpms go.
Default 09-23-2021, 01:43 PM
Is it safe to run map 1? I can try different 93/94 octane fuel what am I looking for in the log to see a postitive change?
Default 10-06-2021, 01:29 PM
1st log is Shell Vtech 91 Octane with no Ethanol 2nd gear pull
2nd log is Petro 94 Octane with 10% Ethanol 2nd gear pull
I know 2nd gear is not ideal but its easier then trying to get a 3rd gear pull at the moment.
Im ok with sticking to map 1 if one of the logs this is completely safe otherwise I give up and
I am just going to take it out. I do not want to use an octane booster.
Just want to know if one is safe and if Im getting knock? I don't really understand the logs.
thanks
Default 10-07-2021, 10:13 AM
Your Petro log wasn't a very good log as it appears you spun so the DME would pull timing and you let out of it. Based on those logs...I'd stick with map 1 until you are able to run better fuel or get a better log on Petro.
Default 10-07-2021, 10:35 AM
you are 100% correct it did spin a bit so I will now focus on trying to get a 3rd gear pull with the Petro 94
thank you
