Denys_Flexer Denys_Flexer is offline
Car: Kia stinger
Default Boost 0 please help - 09-07-2021, 03:04 AM
Hi,I have stinger 3.3 rwd, I installed new intercooler, after few race, on next day I was going to my work on stinger,
And did few acceleration , turbo was ok saw about 17.8 19 psi on jb4, after this I continue ride,
And on next crossroads tried to accelerate I saw some 2k rmp to 6 k with no boost and turbo stop working,
I write some log, after restart car everything is ok, but it's happened about 3 time today, please help.
Car: Kia stinger
Default 09-07-2021, 03:12 AM
Forgot about one thing, few days after install new intercooler, I got error 0049 and check engine light.
Default 09-07-2021, 10:43 AM
Near the end of your log, you're hitting boost of about 15psi on map 0.
Make sure all errors are cleared and then do a proper log on map 0 and 1, lets see how those look.
For proper review and the JB4 to adapt, please do logs in 3rd or 4th gear from 2K rpms to redline at wide open throttle.
Car: Kia stinger
Default 09-08-2021, 01:17 AM
Check engine light again 0049, got few logs, please suggest what's wrong
Idk how it's write the log but it's about 3 different times or 4, with map 0 1 2 with restart car after check engine with turbo off or low psi
Car: Kia stinger
Default 09-08-2021, 03:46 AM
As I saw when boost was about 0.2 bar it's was 6999 rmp but can't see it on log, and I think it's not ok if I have 3+ - 7k rmp and boost only 0.2, I'm abit scared about engine now after this heppend few times
Default 09-08-2021, 10:28 AM
Most of the log looks normal but you are having the random issue of no boost on map 0 and 1. Were you clearing the error between each pull? The only thing I can suggest is to check your connections and JB4 board. Make sure there is no moisture and the connections are tight.
Car: Kia stinger
Default 09-08-2021, 11:40 AM
Only with map 0 got chech engine, after remove no check,
On map 2 it's feels like car can run much more acceleration ,but not doing it's feels so. Is it possible to run some adaptation for jb4 ?
And any way to do log with out manual shift ?
Car: Kia stinger
Default 09-09-2021, 04:56 AM
So it's repeat again I'm map 2 got pedal 100% down, got boost about 16 18psi, after it's feels like boost got cut off and something like breaker pedal pushed, and turbo go off no errors, continue ride with no boost on any rmp, I got blow off maybe there is some problem or new Wagner intercooler. Some auto log writed I think before it
Default 09-09-2021, 07:58 AM
Looks like a p0049 overboost fault, what mods? You'll likely need JB4 EWG connectors to dial down WGDC.
Car: Kia stinger
Default 09-09-2021, 08:07 AM
Rwd stinger 3.3 gt2, Down pipe, borla exhaust,turbosmart blow off, jb4 map2, Wagner intercooler, bsm intakes, diff brace, and alloy wheels with 285/35
Car: Kia stinger
Default 09-18-2021, 03:12 AM
Hello today installed ewg did few runs, turned on bit 6, got overboosted with default value ff, 2 last run I think I lower FF value to 40
Car: Kia stinger
Default 09-19-2021, 07:08 AM
And question do I need bit6 turn on or off I don't really understand what's for it ?
Previously I had some sucks ECU tune on base ECU, I asked to put back some default ECU settings to not broke car, I think they did is this my case ?
Default 09-20-2021, 07:11 AM
Bit6 is only if you're currently flashed with an ECU tune.
Either way if you continue to have over boost continue to lower FF. 35, 30, 25, etc as needed.
