V8EATR V8EATR is offline
Car: 2019 Stinger
Default Brake snip fail - 09-04-2021, 09:18 AM
So I did the brake snip mod and I have a cel with p2127 and the car is in limp mode, says throttle voltage too low and the car is in limp mode. I double checked and it's the right wire. The a is flashing on the dash as well. Code won't clear, its a hard fault.
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 09-05-2021, 07:53 PM
Throttle position sensor. I know you double checked but can you take a pic of the wire you cut. It still sounds like the wrong one. Did you put it on a switch? Was it one of those powered toggle switches with a light?
Car: 2019 Stinger
Default 09-05-2021, 08:00 PM
It was definitely the wrong one. Although it's concerning cause it's definitely pin 83 according to the diagram. I just cut the other green/black wire and it worked. All is well now
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 09-07-2021, 07:21 AM
Glad to hear it!
