Mendozaz31's Avatar
Mendozaz31 Mendozaz31 is offline
Car: 07 335i
Default 435i VTT 1 log review - 05-18-2021, 07:08 AM
Hello. This is my first health log, on the F n55 platform (map5). My goal is pump flash map 7 18psi daily. Any help is appreciated. Thanks.
14 435i F32 M-sport EWG Auto
JB4 Mhd Back end, VTT Stage 1, BMS Intercooler, BMS charge pipe, VRSF DP, BMS OCC, BMS CAI, 2 step plugs, Turner turbo inlet, Turbosmart diverter, Racing diff LSD conversion, 3.5 map, Eldor coils, XHP stage 3 flash, BMS WMI (12).
Default 05-18-2021, 09:01 AM
Looks clean so far.
Mendozaz31's Avatar
Car: 07 335i
Default 05-18-2021, 09:39 AM
Thanks Steve. I’m trying to run map 7 18psi no taper. Can I run it on 93 or do I need an e30 mix. Let me know. I’ll try to post a lo go on map 7 just 93. Thanks.
Default 05-19-2021, 09:54 AM
Per the map descriptions.
"Map 7: Race gas map. Absolute target of 18.5psi. Requires straight unleaded race gas."
Mendozaz31's Avatar
Car: 07 335i
Default 05-23-2021, 03:37 PM
Hereís map 5, 4th pull with added 3.5 map sensor. Eventually Iím going BMS WMI. Please review log. Thanks.
File Type: csv P10_M5_R1_N55 EWG VTT1_210523_172600.csv (5.6 KB, 61 views)
Default 05-24-2021, 12:00 PM
HPFP is struggling and a couple minor timing corrections but otherwise looks pretty normal.
Mendozaz31's Avatar
Car: 07 335i
Default 05-24-2021, 12:24 PM
Ok great. I’ll leave it as is. My end goal is 400whp. I’ll add WMI in the near future and re log. Thanks Steve.
Default 05-25-2021, 10:19 AM
WMI will help out the HPFP so I'd recommend doing it sooner than later if you're going to continue running that much boost.
Mendozaz31's Avatar
Car: 07 335i
Default 06-09-2021, 06:37 AM
Here it is. Log check map 3 WMI. Thanks
File Type: csv P10_M3_R1_N55 EWG VTT1_210609_065321.csv (5.5 KB, 53 views)
Default 06-09-2021, 09:53 AM
Looks pretty clean
Mendozaz31's Avatar
Car: 07 335i
Default 06-09-2021, 12:21 PM
Dave you think the nozzle 12 is fine. Or should I get a smaller one. Also Iím not sure on the jb4 ethanol setting. Is it bit 3 and or bit 7? Thanks.
