Default Finally got our hands on a new 2.5L! - 04-23-2021, 08:04 PM
BETA 2.5t and 3.5t JB4 system available here: https://burgertuning.com/collections...and-3-5l-turbo
Was able to track down a local 2021 Genesis GV80 2.5L today for a little long overdue JB4 development and dyno testing! This engine uses the same connector system as the new 3.5L, both of which will share a new JB4 2.5/3.5 harness variant.
Anyway, the 2.5L is pretty stout and responded really well to extra boost. Vehicle is 100% factory (factory plug gap too) and we did a few runs on 91 octane (didn't want to really push it on 91 since we were just borrowing it), and then added in a couple gallons of E85 for E20+91 testing which should be fairly similar to 93 octane. Result was a gain of around 65whp and 79wtq! I have no doubt once we spend a little more time with the tuning, add an intake, go up to E30, etc, this little power plant will see 350whp.
We will be adding BETA systems to our site shortly and will make another post talking about the connectors we're using that aren't quite right but good enough for the moment.
Car: 2020 Kia Forte GT
Default 04-23-2021, 09:24 PM
E20 is higher octane and oxygen content than 93 and it's not even close.
We should do a fuel test to show the JB4 is truly capable of.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Burger Motorsports Water Methanol (45/55 mix)
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Default 04-24-2021, 07:57 AM
E20 just means 20% of the fuel is ethanol. That doesn't tell you what the other 80% is which plays a large role in effective octane. That other 80% can be anywhere from 87 octane (or lower!) up to 93 octane, providing a huge effective range. In this case the 20% E85 (80% ethanol, 20% 87 octane) was then mixed with 80% 91 octane. So we estimate the effective octane around 93. Plus or minus a point.
Default 04-24-2021, 09:12 AM
True, the effective octane only tells part of the story. The bump in oxygen content is the real benefit of blending.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
johnnhp johnnhp is offline
Car: 2019 Hyundai Sonata 2.0t
Default 04-26-2021, 01:57 PM
Sweet! I have and intake and 3” midpipe with 3” ***-back already on this N-line running 93 octane.
Really interested to see improvements with all that airflow restriction gone.
When can we expect to be able to get the nee harness to tie into our JB4s?
2021 sonata N-Line 2.5t, AEM Intake, HKS SSQV BOV, CP-E 3 midpipe w/high-flow-caat, CP-E Austentine caatback, Rev-9 Hyper Street 2 coil-overs
Default 04-26-2021, 04:21 PM
Originally Posted by johnnhp
Sweet! I have and intake and 3 midpipe with 3 ***-back already on this N-line running 93 octane.
Should have the BETA systems on our site tomorrow. They are made to order so we'll see on shipment times, I don't expect that to take too long though.
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 04-27-2021, 10:06 AM
What kind of gains are you getting on 91 alone?
2021 kia K5GT.
csu87 csu87 is offline
Car: 09 335xi
Default 04-29-2021, 08:25 AM
30ish whp 40ish wtq based on the dyno
Default 05-12-2021, 09:19 AM
Definitely can tell difference rolling to 100+. Car gets up in speed quicker now. Off lone I’ve only been able to get like 5.4sec dragy 0-60 with launch control in sport+ mode letting it shift automatically. That’s probably mostly me needing to practice and adjust launch rpm and manually shift, and finding a nice spot as close to 0 degree incline as possible outside going to dragway.
rdumont rdumont is offline
Car: 2021 Sonata N-Line
Default 05-16-2021, 08:21 AM
Do you suggest replacing plugs on the 2.5T tune?
1st timer's Avatar
Default 05-16-2021, 08:27 AM
What plugs are in the 2.5T?
2021 kia K5GT.
Default 05-16-2021, 03:33 PM
Why replace plugs in a brand new car?
Re-gap them down to whatever Terry suggest.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
Default 05-16-2021, 03:44 PM
Too early to say, most customers are running factory plugs, and even the factory gap, without issue. We'll see how it pans out longer term.
2.5stinga 2.5stinga is offline
Car: 2022 2.5L Stinger
Default 05-19-2021, 04:59 PM
Hi Terry, any ETA for intakes on the 2.5? From you guys or any other manufacturers.
Patiently waiting for your MAP connectors .
btstarcher btstarcher is offline
Car: Hyundai Sonata N-Line
Default 05-20-2021, 12:00 AM
Installed mine a week ago, definitely an improvement. I've been blending e85 to at least an e30 mix, using map 3 but considering trying to use map 4. Is there anything I should be worried about? Since the car is otherwise stock, I'm pretty sure boost will stay under control; I'm not familiar with this platform but in the past I've had issues with boost creep for lack of backpressure (after removing the cats).
Default 05-20-2021, 09:26 AM
We haven't started development on that yet, car is still too new. But down the road expect to see an intake from us for it.
Default 05-20-2021, 07:26 PM
Thanks for the info! I would totally let you guys guinea pig the car if I was in cali.
Best of luck guys.
Default 05-21-2021, 11:20 AM
Post up the CSV log so we can take a look!
Default 05-21-2021, 01:39 PM
About that......LOL
I say "installed," because technically it's connected to the sensors and working. However, I haven't had time to connect the cable to the OBD2 port. Hopefully I'll get it done this weekend.
I have a BT OBD2 adapter and can log using my Torque application, but somehow I don't think that will be enough.
Default 05-26-2021, 01:33 PM
So I am assuming there are no fuel wires or EWG wires for the 2.5 yet.
Terry was that dyno run done using ONLY the JB4 installed? I wanted to wait for proper MAP connectors before ordering but my JB4 tuned license plate is making me feel like a poser haha.
g80svt g80svt is offline
Car: Genesis G80 Sport
Default 05-26-2021, 02:28 PM
Great numbers. I see you mentioned intake, when are the G80 3.3T guys getting an intake?
tscandal tscandal is offline
Car: 325
Default 07-12-2021, 05:20 AM
I have a 2021 G-80 with the 3.5 TT. It's a nice powerplant but could use some "Oomph" to keep up with the German Guys.
* Is this setup good for the 3.5 that's in the G80's??
* Has there been any testing done with the 3.5TT for gains with the JB-4 ??
1st timer's Avatar
Default 08-03-2021, 10:21 AM
Are you able to get readings from all 4 cylinders on the 2.5T K5GT /N-Line?
2021 kia K5GT.
jaddi85 jaddi85 is offline
Car: Kia Stinger
Default 08-10-2021, 10:43 AM
Any update on when this will get out of Beta or when the connectors will be available?
Jesse2321 Jesse2321 is offline
Car: Hyundai Sonata n line
Default 08-10-2021, 04:37 PM
I've taken the next step of going to hyundai myself for my Sonata N line to get the connectors to make it somewhat safe but Hyundai is not selling the connector part currently probably due to covid. the only way is buying the harness and no one is going to do that lol... so maybe this is why its holding them back so hard. since the 1.6 and 2.5 are 2 totally different connectors which is dumb
