n55fan n55fan is offline
Car: 2015 BMW 335xi
Default Map 3 Logs - 03-31-2021, 06:58 PM
Hi Steve,
Got around to installing the BMS Meth kit. Set-up is just a single BM7 nozzle with 50/50 meth right now. BMS Race EWG BEF, JB4 Map 3, N20 TMAP, FBO. Did a little bit of tweaking but I wanted your opinion if I turned it up any more from here. Thanks!
Default 04-01-2021, 09:07 AM
Looks good so far.
Car: 2015 BMW 335xi
Default 04-01-2021, 10:16 AM
Looks good so far.
Awesome, thanks! Going to turn adder up to 80 and post 2 more logs. I had it set at 80 previously but was noticing a gap between target and actual boost >21psi. Assuming this is the stock diverter valve struggling?
Car: 2015 BMW 335xi
Default Need some help - 05-07-2021, 03:07 PM
Looks good so far.
Hello Steve & others-
Need some help diagnosing a possible issue here. Just had the 2nd meth BM7 meth nozzle put in and the shop installed the tee fitting to split the line a little further back than they needed to, so now I have about 3ish feet of line running from each nozzle to the tee fitting, which is located now right at the firewall. I think all this extra line is causing only 1 of the nozzles to get flow and the 2nd one to get little to no flow at all. Is there any way to tell this by logs? I thought putting the 2nd nozzle in would let me lower my FOL and I would see my fuel trims go negative but the logs look to be the same as when I had the single BM7 nozzle. This is on 50/50 mix, MHD BEF, Map 3
Thanks for the help!
Default 05-10-2021, 11:23 AM
Can't tell anything about particular nozzle flow but yes, more meth should lower trims and allow you to lower FOL. That said, IAT's are dropping and trims/AFR's are fine.
435gc 435gc is offline
Default 06-12-2021, 10:34 AM
You ever get that ps2 in?
