(#251)
Default 07-11-2020, 08:32 AM
Log looks fine, you can try raising FF to 60.
On faults if they return then you'll need an updated 2580 on the JB4.
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 07-12-2020, 12:15 AM
Was excited to raise the FF on my way to work this morning. Ran into the same issue of barely any boost and the car feeling choked. Backed it down to Map 0, Bit5 on and same issue. no CEL.
Afterwork turned the car on and had the 2564 and 2588 codes again, I guess I need the updated 2580.
Let me me know what you need from me.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Car: Stinger 3.3T
Default 07-12-2020, 10:32 AM
Car runs ok after clearing the codes, but they comeback after having the car turned off for a few hours.
Here is a high speed run on Map 3 and FF 60. Let me know if all is ok.
Also, please let me know about getting the updated 2580.
Default 07-12-2020, 11:22 AM
If you got the JB4 new just email us your address, if not we have them on our site for $25.
Log looks clean to me!
Car: Stinger 3.3T
Default 07-12-2020, 12:15 PM
Thanks, email sent.
N20_to_VR30 N20_to_VR30 is offline
Car: RS400
Default 07-14-2020, 06:22 PM
Getting a code 2563 that the JB4 won’t clear. Connections are good and tried v17 and v18 but the code persists. Looks like it’s a boost signal issue. Any ideas on remedy? Connections are tight and this is new. EWG wires have been on for about a month now.
Talloneus Khan's Avatar
Talloneus Khan Talloneus Khan is offline
Car: 2018 kia stinger
Default 07-14-2020, 07:18 PM
can somebody post a screenshot of thier user adjustment page? I think I may be adjusting the wrong values
Default 07-14-2020, 07:51 PM
think I figured it out! Log check, first run with wires, more to come
Car: Stinger 3.3T
Default 07-18-2020, 01:28 PM
Got the 2580 chip, thanks. Seems to be running much better now.
Reduced the FF from 60 to 55. Felt like it spiked a little too much on kickdown.
Log attached, let me know.
Default 07-18-2020, 02:32 PM
What you could also try is more FF but less PID gain, since you'll note on tip in it's mostly PID gain driving up WGDC to force boost to target.
atr1 atr1 is offline
Car: Stinger GT
Default 07-19-2020, 12:48 AM
How come FF decreases with RPM on this log?
On my car and other cars I've seen so far FF usually increases with RPM.
Default 07-19-2020, 08:44 AM
It's indexed on boost target which is decreasing.
Default 07-19-2020, 11:24 AM
did some runs since installing the ewg wires, got some logs, see if anything needs to be changed. definitly pulls harder in the top end then it used to before the wires
Default 07-19-2020, 01:05 PM
Set the app to combine all logs in to one file next time.
From what I can see here though everything looks good to me!
Car: Stinger 3.3T
Default 07-19-2020, 11:56 PM
Really liking the EWG mod, definitly game changer.
Reduced PID to 15. Seems to help with the boost spike at kickdown. Is my boost taper at top end normal or needs more adjusting?
Default 07-20-2020, 07:52 AM
Normal taper but you could always try increasing duty bias up top to see what effect it has.
Set app to combine lines.
duty_15 duty_20 duty_25 duty_30 duty_35 duty_40 duty_45 duty_50 duty_55 duty_60 duty_65 duty_70
50 50 50 50 50 50 50 60 70 80 90 100
Car: Stinger 3.3T
Default 07-21-2020, 08:35 AM
Ok started with your suggestion and immediately went to boost cut and got a 0049 code, even if I roll in the throttle to avoid any spike it will still boost cut, reduced duty by increments of 5 until i reached something that is smooth and pulls hard, logs attached. Happy with this setup
Fuel: 98ron (93pon)
WMI: Snow Performance
Firmware: v18
Bit5: Off
PID Gain: 15
Auto Shift Boost Redux: 60
FF/Wastegate Adaption: 60
Duty Bias;
duty_15 - 50
duty_20 - 50
duty_25 - 50
duty_30 - 50
duty_35 - 50
duty_40 - 50
duty_45 - 50
duty_50 - 50
duty_55 - 55
duty_60 - 60
duty_65 - 65
duty_70 - 70
Default 07-21-2020, 08:42 AM
Looks solid to me here
SmallAxe SmallAxe is offline
Car: 2020 Kia Stinger GT2
Default 07-24-2020, 01:00 PM
Hi I wanted to post a couple logs. I just installed the EWG connectors this morning. No problems or codes so far. Running on almost an empty tank of 93 octane and what I thought was a flat piece of road(no draggy). The JB4 said it was almost 4 seconds flat 0-60. Best I had seen before was 4.4. Still feel like it's lagging a bit on launch.
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 07-25-2020, 02:23 PM
Installed the ewg connectors and updated the settings. Immediately threw a couple of codes, but I double-checked the installation, cleared them, and so far they haven't returned. This log is too short, but anything obviously off?
Default 07-25-2020, 03:39 PM
Seems OK. If codes return will need a 2580 update.
Log looks good to me. Do the brake boost switch and brake-boost it to really launch.
Default 07-25-2020, 05:09 PM
Thanks, I've been looking into it. I'd like to see what a launch from 4 or 5k rpm would feel like. Transmission worries me a little, pretty hard shift from first to second. Doesn't seem to be many complaints on trany problems, so I guess that's good.
Default 07-25-2020, 05:36 PM
When you brake boost you'll usually launch around 2-3k but it actually works and spins the crap out of the tires.
mitchyboy mitchyboy is offline
Car: Kia Stinger GT
Default 07-25-2020, 06:40 PM
Got the EWG wires running fine wiithout codes
Can you please check the attached log and see what you think?
