(#151)
HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default 03-31-2021, 12:11 PM
I'm interesting in getting this for my S8. I've had a JB4 in my N54, N55, and N63TU, so I'm very familiar. I'm especially interested in running ethanol mixes. Is this supported? E30 would be quite the hot ticket I imagine...
Default 03-31-2021, 12:16 PM
Hi, up to E35 there is no issue running it.
2021 VW Golf 8 R
Default 03-31-2021, 12:19 PM
That's what I wanna hear haha. I wonder if the S8 could break into the tens with some E30 and JB4 only 😁
Default 04-07-2021, 08:54 AM
Hi George,
I emailed you as well. But here's a log of Map 1, 93 octane, 2013 S8. Stock hardware, JB4 only. Let me know what you think! I'd like to get more aggressive on ethanol mixes.
Thank you,
Adam
Default 04-07-2021, 09:04 AM
Hi George,
Thank you,
Adam
Hi Adam,
Check your email. My network has been whipping so sometimes mail lands up in drafts. Sent the response through now.
2021 VW Golf 8 R
Default 04-07-2021, 09:38 AM
Hi Adam,
Awesome, thanks! Map 2 coming up!
Jeff @ BMS's Avatar
Jeff @ BMS Jeff @ BMS is offline
Car: 430i
Default 04-07-2021, 03:27 PM
I normally run E40 with 91 on map 2 with no issues on my 2018 S6 which was our development car and it pulls like a freight train. Of course, the quality of fuel, elevation, and other factors can vary so logging is always best, but our S6 has no issues with 7-8 gallons of E85 topped off with 91.
Default 04-08-2021, 10:39 AM
Hi Adam,
Sent map 2 log and notes to your email! Thanks!
Adam
Default 04-08-2021, 10:52 AM
Thanks for the note Jeff! I think I'll be heading that way. With straight 93 in the tank, map 2 wasn't mustering nearly the same timing as map 1. We'll see what George thinks.
Adam
Default 04-08-2021, 11:50 AM
In case other people are curious, logs 1 and 2, attached. Both are 1/8 mile dragy runs on 93 octane only. Map 1 "felt" noticeably stronger, and the dragy concurs.
Map 1: 7.37@96.22, 1.78s 60', 2200ft DA
Map 2: 7.60@93.75, 1.80s 60', 3200ft DA (different days, and I'm at ~1200ft elevation)
Default 04-14-2021, 05:18 PM
D4 S8 down to 7.2@99mph with JB4 only. Shooting for sixes with George's help. I think we'll get there!
snowfree52 snowfree52 is offline
Car: SQ5 354 / Golf R 310
Default 04-23-2021, 01:37 PM
Hi ! I have a SQ5 with a JB4 and happy customer !
Just bought an RS6 C7 performance and was wondering what kind of HP it would do with the JB4 ? any 0-60 and 1/4mile ?
Is there a tutorial for the installation ?
AUDI RS6 performance C7.5 JB4 map 6 - 30% E85 693HP / 880Nm
esirtype esirtype is offline
Car: Audi s7
Default JB4 Questions - 04-29-2021, 07:57 AM
Hi, I'm new to the forum. I've had a JB4 on my Audi S7 for about 4 weeks now. I had a few questions that I'm hoping someone can chime in on. I've stacked the JB4 on top of my tune, since I read good results with other people stacking.
First, my mod list to my C7 S7
-EPL Stage 2 tune and transmission tune
-Intake
-3" down-pipe$
-3" exhaust back to the mid-pipe (factory the rest of the way)
My questions:
1. Has anyone had issues with the app freezing under full throttle?
- I am running a RSnav head unit with the JB4 app on it. I've tested this on map 0,1,2, and 5 and all lockup the app. I have to hit disconnect and connect to start seeing the readouts from the gauges.
- I can't get a datalog since the app freezes (99% of the time)
- I maybe able to data log with the Torque app (I haven't tried yet)
2. Has an experienced where the car is not consistent and a loss of power?
- I've noticed that when I hit heavy boost, the app freezes and the power is reduced. When I look at my in dash boost gauge, it's locked at the midpoint as if it's on the factory tune. I'll see full boost and then all of a sudden boost drops to the midpoint.
- Since the app locks, I can't get a data log 99% of the time. The few times it didn't lock, I did not see any timing pulled in the logs and I did not see AFR any leaner than 12.5 under heavy boost.
One of my observations is that when I do a firmware upgrade, the JB4 is awesome on the car. It pulls some much harder in the low end and I can do a few data logs. After a few pulls it starts to act up.
3. Is anyone using the WMI feature? I have an AEM water/meth setup that I am waiting to put on my car and would rather use the JB4 for WMI than the AEM unit.
Thanks,
Shawn
MTV MTV is offline
Car: Audi S6
Default JB4 Map 6 Issue. . . - 06-23-2021, 06:57 AM
Hi guys,
I've been running Map 6 for the past months without issue. Car pulled hard and did so consistently. Only issue I had encountered in the past was the JB4 not working.... which was resolved with a simple shut down and restart of the car.
More recently - this JB4 not working issue has happened a couple times in the past week. Example: Car gets up to temp and I mash the throttle to merge onto highway and it pulls like stock. Restart the car and it's pulling hard again.... I'm thinking there's an issue with my unit.
The more concerning issue - is my Map 6 not working as it should. I did a couple pulls this morning.
Graph below stipulates the following:
  • First pull in Map 6
  • Second pull in Map 2
As you can see... Map 6 is pulling throttle for some reason....
Default 07-09-2021, 01:42 AM
Hi, just went to the dyno with my RS6 and JB4 map 6 :
Default 07-09-2021, 05:56 AM
Looks great. Thats decent power.
2021 VW Golf 8 R
Default 07-10-2021, 04:31 AM
Thanks, do you think it would be better to smoothen the curves ?
Also I feel the transmission would work better with a transmission remap
mmurphyS7 mmurphyS7 is offline
Car: 2017 Audi S7
Default 07-13-2021, 11:24 AM
Wow! What other mods have you done? Those numbers look massive.
I've got a C7.5 S7 with sport exhaust. Just received my JB4, not yet installed.
Wonder what mine will do once installed.
Default 07-13-2021, 02:17 PM
Hi, the car is completely stock
I have an ITG ifilter coming next week, will see if it's better.
Default 07-18-2021, 06:27 AM
-Intake
-3" down-pipe$
My questions:
Thanks,
Shawn
I seem to be having a similar issue now. Occasionally when the car does a wot shift from 2-3, it will just sort of fall on it's face, like it's pulling boost. This is on E30ish and map 2 on 2013 S8. I can't seem to record it on a log either. I'll keep trying to get a log of it so we can see what's going on.
Car: Audi s7
Default 07-31-2021, 10:48 AM
I was able to did through some logs. I find if I manually start data logging, I can capture the entire run, even when the gauges appear to be locked up.
I've attached a screenshot for reference. This is not the most extreme examples. Most of the time when the JB4 acts up, it's only running 10PSI. You can see the difference between boost target and actual boost. You can see in the screenshot, I'm hitting around 18psi. I have an EPL stage 2 tune on the car and it boost so either 20psi or 21psi.
In my case I only run 93 octane. I did add 4 gallons of E85 and the rest 93 octane once and saw no different. Also, it doesn't matter what gear I'm, I still get the same results. I've tried map 1 and 2. I even tried map 6 with all the boost settings set to 0psi. It still falls flat on its face. The only option is map 0, which is pointless.
I'm hoping someone at Burger Motorsports can chime in an help.
Shawn
Default 07-31-2021, 12:03 PM
Shawn
Email the log to george@burgertuning.com as there is more too see on it. Map 1 and 2 might be adding too much boost over a flash tune and its going into limp home mode.
2021 VW Golf 8 R
14AudiS7Jay 14AudiS7Jay is offline
Car: 2014 Audi S7
Exclamation App Freezing, Car bogging - 09-28-2021, 03:45 PM
-Intake
-3" down-pipe$
My questions:
Thanks,
Shawn
Hello, Iíve been been having a similar issue also. My app freezes and feels like the car is bogging down, could be pulling boost. Iíve had the JB4 on my 2014 S7 for about 3 months now and it has been having this problem since I installed it, it seems. My connect kit got melted from initially put JB4 next to coolant reservoir, and Chris from DMD shipped me a new one free of charge, I installed it the other day, and my car is still having the same problem, but my JB4 is now mounted under the passenger side of the cowl. Iím running on Map 2, but Iíve used Map 3 and I use an octane booster with every fill up. Iím going to try Map 1 tomorrow to test the results. I bought the car from a local dealer and Iím not sure if it might have an ecu tune on it. I will chime in tomorrow with my results, I think I will try Map 0 also for the heck of it🤷🏻*♂️
Default 09-28-2021, 05:21 PM
If you need support you can email george@burgertuning.com. We don't check this forum as often as we should.
Car: 2014 Audi S7
Thumbs up 09-28-2021, 06:03 PM
Thank you Terry. I have been corresponding with George! Goodnight!
