(#3351)
Default 07-04-2020, 01:47 PM
Originally Posted by Boelli134
Nice!
what is EWG?
can you explain it?
should I try Map5 again?
It's not boring yet, but maybe soon
EWG info here: Stinger 3.3L EWG Connectors - N54Tech.com - International Turbo Racing Discussion
djerickd djerickd is offline
Car: 2019 GTS
Default 07-06-2020, 06:28 AM
Would we notice anything special with the ramped up CANBUS sampling? Faster guages?
atr1 atr1 is offline
Car: Stinger GT
Default 07-06-2020, 07:42 AM
Gauges are already fast
Default 07-06-2020, 08:18 AM
Datalogs take up a little more space? It's just a little internal housekeeping to keep JB4 ahead of the pack. The extra bandwidth will come in handy when we get deeper in to the autotuning map development.
Car: Stinger GT
Default 07-06-2020, 08:25 AM
Can we expect a test version before the end of the year?
Default 07-06-2020, 09:40 AM
I think we can manage that. I've setup the speed delimiter in the firmware now I just need to test that in car and button it up so we can move on to the next round of updates.
Default 07-09-2020, 12:41 PM
Was able to borrow a customers 1.6L Forte today, working on getting cyl 2-4 timing, gear, and in dash map switching active. Will be curious to see if the updates work for all 1.6L models!
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 07-09-2020, 12:43 PM
Will this be applicable to the 2.0T as well?
2021 kia K5GT.
Default 07-09-2020, 03:12 PM
I just posted the firmware under alpha v19, after loading set FutureUseA = 2 to enable the alternative settings. And lets see if it works for you.
The Veloster N uses the normal settings same as the Stinger but the older model 2L this may work.
niccuany niccuany is offline
Car: 2018 Elantra GT Sport
Default 07-10-2020, 10:30 AM
I installed v19 on my Elantra GTS, and set FUA to 2. The wiper mode switch does NOT work for me. Maybe there was something else needed, or I’m not doing it right, but right now still not working. Just wanted to give a heads up.
tfizzle999 tfizzle999 is offline
Car: 2020 Kia forte gt
Default 07-11-2020, 04:57 PM
I loaded v19 and set future use to 2 and ign 2-4 isnt working on my forte gt but fuel pressure logging parameter is which is noce
Default 07-11-2020, 06:20 PM
Yes looks like the 2020 is different, we'll have to add another FUA option for those once we get one in the office!
Does the wiper map switching work on it if enabled?
Default 07-11-2020, 06:52 PM
I'll try the wiper map switching tomorrow to verify for you and where are you guys located? I'm probably to far to be able to bring my car there but figured I'd ask
Car: 2020 Kia Forte GT
Default 07-12-2020, 02:05 AM
Terry I live in Reseda. If you need my car let me know I'm available during the day.
2020 Forte GT Manual Transmission
Default 07-12-2020, 07:57 AM
OK sounds good! Drop me an email terry@burgertuning.com we'll arrange to trade cars for a day, the Stinger for the Forte.
johnnhp johnnhp is offline
Car: 2019 Hyundai Sonata 2.0t
Default Best way to do a run for a log check - 07-13-2020, 08:55 AM
What is the optimal way for me to do a run to get a log check? 0-60? Rolling from X gear?
Also, does the JB4 app have to be connected for the JB4 to be active? Meaning if you had it set to a previous Map and you didn't connect to it would it still run the previous map?
Running Map 4 with 93 Octane and 30% E85 in tank.
2019 Sonata 2.0T
Dual baffle oil catch
HKS BOV
AEM Intake
HKS 45XL plugs
3" CPE test pipe into 3" CPE Austentine ***-back
Car: Stinger GT
Default 07-13-2020, 09:04 AM
2019 Sonata 2.0T
HKS BOV
AEM Intake
HKS 45XL plugs
Two methods
1) Multi gear WOT pull from 40mph to 120+
2) 4th gear 3000rpm floor it until red line
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 07-13-2020, 11:17 AM
Log of it? We might be able to lean out AFR to keep pressure up.
Just as a recap, I am getting a Safety Error 3 for Fuel Pressure Low.
I don't have a log from when it cut back to 0 but here is a recent log I took, but not sure if that will be helpful.
It happened twice so far this week. Once on Map 3 and Map 2.
Default 07-13-2020, 11:32 AM
Update to v19 firmware and grab another log
khancerto's Avatar
Default 07-13-2020, 11:39 AM
Alright. I'll do that. Anything I should do during the drive to help?
Default 07-13-2020, 12:56 PM
Just do some more full throttle logs after updating!
Default 07-13-2020, 02:46 PM
Log looks ok to me, but still familiarizing myself with reading it. AFR and boost seem ok. I am not sure why but I have had the car do something where it doesn't really spool boost and gets heavy. Not sure if it was too lean and the JB4 kicked it out of map? Can I switch map while driving or should I always restart vehicle and then change map before driving?
I'm also playing with the stock settings on the vehicle (it has smart, eco, sport, etc.) which I believe are various stock maps and seeing how they play with the JB4. I am looking for a dyno in my area to see how much WHP this is running. Once I do I'll have them do a run with Map 0 and then with Map 4 to see what the difference is. Of course I'll let y'all know.
Default 07-13-2020, 03:17 PM
You can check last safety to see if it changed to map0/disabled itself
khancerto's Avatar
Default 07-13-2020, 04:27 PM
Ok so here's with the firmware updated. Using Map 2 with mostly 91 octane. (recently filled from almost empty where the previous tank was a mix of E85 and 91 3.5ga E85 + the rest 91).
Default 07-13-2020, 04:34 PM
As a test set FUA = 2 and grab another log so I can see if the fuel pressure channel shows up that way.
