(#301)
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 09-18-2021, 05:27 PM
Originally Posted by rbf351
Did exactly as the instructions say, but i don't think the meth is flowing.
I was able to purge it with no issues, and the FSB has a red blinking light, not green as the last page of the instructions say.
here is my log.
Could be FSB unit is not good. I would reach out to burger tuning
2020 Stinger GT1 AWD CERAMIC SILVER W/RED INTERIOR
JB4 W/FUEL WIRES & EWG WIRES
BMS INTAKES
BMS WMI KIT
BMS OCC
FUEL IT FLEX FUEL KIT
BORLA EXHAUST
STOPTECH FRONT AND REAR PADS
DENSO 5346
SEIBON CARBON FIBER OEM HOOD
NICHE 20" WHEELS MATTE BRONZE
LLUMAR STRATOS CERAMIC WINDOW TINT
STEK DYNOSHIELD FULL FRONT CLEAR BRA
CERAMIC PRO SILVER PACKAGE
OEM PUDDLE LIGHTS INSTALLED AFTERMARKET
OEM FRONT AND REAR SPLASH GUARDS
DRONE MOBILE REMOTE START
rbf351 rbf351 is offline
Car: Stinger
Default 09-19-2021, 03:09 PM
I did. sent over an email to their support address.
I know today is a Sunday so i don't expect a response.
Default 09-20-2021, 09:45 AM
Post a log here. On the Kia platform most common mistake I've seen is people selecting WMI bit7 for optional PWM control which may disable WMI all together unless other settings are set. WMI Bit7 should be OFF by default.
Car: Stinger
Default 09-22-2021, 11:07 AM
here is the log and screenshots of the settings.
I have also double checked the wiring, and the pins are in the proper place.
*edit*
i see Bit 7 is on, so i just took the car for a quick ride with Bit 7 on and Bit 7 off. still getting 0 on the WMI.
Attached is the most recent log
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 09-22-2021, 11:33 AM
Shut everything off under Ethanol
Car: Stinger
Default 09-22-2021, 11:48 AM
that did it.
now how do the logs look for the quick run?
slowstinger slowstinger is offline
Car: stinger
Default 09-22-2021, 02:43 PM
Did a quick run with my friends..Would anybody check the log?
I ues 50/50 and putted boost additive in 40 but seems car didnot run well; will change the WM ratio to 30/70 will help?
Default 09-22-2021, 03:08 PM
Timing corrections what octane fuel you running?
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Default 09-22-2021, 03:09 PM
that did it.
Very short run.. do a wide open throttle pull 40-80+ mph pull this log doesnít show much
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: stinger
Default 09-22-2021, 03:13 PM
Thanks! This is auto log, I will try get a 40-80 log soon
Car: stinger
Default 09-22-2021, 03:15 PM
Shell 91 oct, is this fuel really that bad? This is best fuel in town I can access
Car: Stinger
Default 09-22-2021, 03:28 PM
Thanks. Iíll do it tomorrow morning on my way to work.
Car: Stinger
Default 09-22-2021, 06:09 PM
was able to run it tonight through 2nd and 3rd @100% throttle.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 09-23-2021, 05:02 AM
Timing looks really good, change Meth Additive from 50 to 60 and send another log
Car: Stinger
Default 09-23-2021, 05:32 AM
Thank you. will change the settings when I get into my car later this afternoon, and do a run and post it up here.
Car: Stinger
Default 09-23-2021, 10:23 AM
Here is the new log at 60
Default 09-23-2021, 10:27 AM
Looks good you could try 70 or maxing out at 75 and take a log and we could take a peek and see. Going up to 70-75 you'll probably see another pound or two of boost
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 09-23-2021, 10:31 AM
It's not bad but plug 4 is pulling a bit more than the rest.. 3 deg. Not too concerning but it's super easy to get to and pull out. Check that gap. I'm not sure what they are now but I recommend .022-.026
If you posted the plug type and fuel you were using earlier I'm sorry I missed it. Can you post that?
For now stick with 60 until you verify the condition of that plug. Then I think we can go higher, you're hitting 20 psi now which is good.
Car: Stinger
Default 09-23-2021, 11:32 AM
They are Denso 5346 that were gapped to .022. They have about 3000 miles on them. Iím using 93 gas.
Just pulled the plug, and had to re-gap it, but it's now at .022 and will try it again tomorrow at 60
Also does anyone else have it where the MAP sensor now touches the felt on the hood? Mine has cut it a little. pictures are attached
Default 09-23-2021, 11:55 AM
They are Denso 5346 that were gapped to .022. They have about 3000 miles on them. I’m using 93 gas.
You running any E blends? If not try a couple gallons of E85 that will probably clear most of that up.
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: Stinger
Default 09-23-2021, 11:58 AM
nothing nearby to get any E blend. closest place is 50 miles away. Every place here though sells 93
Car: Stinger
Default 09-23-2021, 03:36 PM
Just ran it again after fixing the plug on the 4th cylinder. it looks better to me than it did earlier
Car: Stinger
Default 09-24-2021, 10:44 AM
did a 3rd and 4th gear run an hour ago. Please let me know if i should try going to 70 or if i should leave it on 60
Default 09-24-2021, 10:58 AM
Looks really good! Try 70 and log
BMS INTAKES
BMS WMI KIT
BMS OCC
BORLA EXHAUST
DENSO 5346
Car: Stinger
Default 09-25-2021, 03:36 PM
upped it to 70. i didn't get to run it full in 3rd, but this is what i have
