(#551)
tymwalk tymwalk is offline
Car: 2021 Mazda CX-5 Turbo Carbon Edition
Default 09-24-2021, 01:15 PM
Originally Posted by Girthbrooks20
Huh, well that doesn't make me feel too good lol.
I'm wondering if you have the right firmware. Ignore my value of 1 in the meth trigger setting. Put zero for you
Default 09-24-2021, 01:27 PM
I just want to make extra sure before I go changing anything, I should be putting 25 in each of the lines on the fuel bias column? Everything is blank on mine right now.
Values only show if you connect to the JB4 for the app to read them....
Girthbrooks20 Girthbrooks20 is offline
Car: Mazda3 Turbo Hatchback PP
Default 09-24-2021, 01:50 PM
Yeah I have a confession to make:
I'm a dumb person.
As Terry pointed out it helps if you connect to the JB4 in the app first.
Havok Havok is offline
Car: 2021 Mazda3 Turbo AWD
Default 09-24-2021, 11:26 PM
Originally Posted by hello_marco
anyone have any pics of their install?
mine just feels like a mess.
i'm new to this so please let me know if there are any issues here also lol
Dude get some zip ties and route the wiring so it follows existing harness. Pull up the plastic heat shield, you will see existing wire loom... I zipped tied my jb4 to the airbox mounts cause i did not like how it sits crammed between the batt box. Most importantly do not leave excess wire flapping around in the engine bay bad things happen if you do that.
Default 09-24-2021, 11:31 PM
Not sure if these pics will load, this forum is not the most mobile friendly
SixPackABS SixPackABS is offline
Car: Mazda 3 Turbo Hatchback (M3TH)
Default 09-26-2021, 10:41 PM
My jb4 bluetooth seems to have a problem. Difficulty getting detected by the phone. Sometimes it can be detected and as soon as you connect the app it will ask you to update the kit. You update the kit and it will seems like its reading then it drops its bluetooth connection. You check the phones bluetooth connection and the JB4 once again cannot be detected. You have to wait until it can be detected again. I have openned the casing and checked and re-tightened the bluetooth dongle connections.
M3TH user
TransModel = A Mazda but identifies itself as a BMW
hello_marco hello_marco is offline
Car: 2021 Mazda CX-30 Turbo Premium Plus
Default 09-27-2021, 04:50 AM
thanks! cleaned it up some.
Default 09-27-2021, 04:52 AM
I had this same issue and emailed support.
Downloading the beta version of the app fixed it
*Android*
https://play.google.com/store/apps/d...o91.jb4_mobile
*iOS*
Join the JB4 Mobile beta - TestFlight - Apple
Default 09-27-2021, 05:12 AM
*Android*
*iOS*
That's the app I am using with the connection issue.
M3TH user
Default 09-27-2021, 05:19 AM
are you sure you're using the BETA version?
if you are, i would try reaching out to support@jb4connectkit.com
Default 09-27-2021, 05:23 AM
That's the app you buy at the google playstore right? That's where I got it.
M3TH user
Default 09-27-2021, 05:35 AM
yes, but you have to sign up for the beta version.
IIRC, if you scroll down, there is a button to join the beta program or something.
Default 09-27-2021, 05:55 AM
@hello_Marco
Joining the Beta right now and it is in progress just waiting. Just to emphasize on the issue the JB4 dongle/bluetooth most of the time this cannot be detected by the phone when you SCAN for bluetooth devices. So seems like not just an app issue.
M3TH user
Default 09-27-2021, 06:00 AM
So based on your OP on the issue, you were able to connect and got a prompt to update. When you tried to update it, the kit goes into DFU mode but then the update fails somewhere there. That's why the BT connection gets messed up.
Default 09-27-2021, 06:53 AM
@hello_Marco
Thanks for the help. The JB4 Beta app solved the issue. As soon detected the dongle right away and connected smoothly. Updated the hex thingy as well. I wanted to test it today but I am on quarantine, lol
M3TH user
Default 09-27-2021, 10:26 AM
Boy this thing is legit and it's not even on sports mode. Short interstate drive.
M3TH user
Default 09-27-2021, 03:59 PM
Turki Turki is offline
Car: 2020 Mazda 6 Signature
Default 09-29-2021, 08:27 AM
Hi... i just discovered that there is 10lbft torque difference between the mazda 6 2021+ models than the older models, for anyone who know is there a difference in the engine itself or is just tuning difference? And is just the mazda 6 or is the cx models have the same thing?
Mazda6 Driver Mazda6 Driver is offline
Car: Mazda6
Smile 09-29-2021, 08:41 AM
The only difference I have heard was the intercooler. I think they switched it from air to water instead of air to air I guess that allowed them to make a bit more boost in return. I don't really like how they made this update for the 2021 models cause I have 2018. But when I test drove the engine it was a bit more refined I wouldn't say much quicker.
Hope this helps I'm sure John would be able to answer this with more information cause he definitely knows a lot more than me.
jcrout7992 jcrout7992 is offline
Car: 335xi sedan 6AT
Default 09-29-2021, 01:25 PM
Iím going to say itís tuning on the CX-5ís as they received the same bump and didnít see any intercooler changes.
Default 09-29-2021, 10:56 PM
Yeah i think the same applies to the mazda 6, I saw my friend's 21 mazda 6, there isn't any change in the engine bay and the intercooler is the exact same, but somehow +10tq so it must be tuning and/or some really minor changes.
dukzzz dukzzz is offline
Car: Mazda CX-5 Akera Turbo
Default AUDM CX-5 2.5T - 09-29-2021, 10:59 PM
Hi Terry,
Long time user of JB4 on other platforms (MKB). Been following this thread slightly.
I'm based in Australia. I have a 2021 2.5T CX-5 and there is a factory soft limiter at around 5,000rpm.
Would this tune remove the soft limiter?
Also, do you need any help down under to run some beta testing
Our fuel quality is a bit different, and temps etc etc
Default 09-30-2021, 07:58 AM
Originally Posted by dukzzz
Hi Terry,
No we're not able to change the rpm or speed limiter with this implementation. But you'll make a lot more power.
Default 09-30-2021, 03:59 PM
Terry,
Any progress teasers for the forum to get excited about?
Thank you!
Default 09-30-2021, 05:15 PM
Too much fun driving the M3TH now. Has anybody else had a hardtime removing the MAP connector?
M3TH user
