MStinger19 MStinger19 is offline
Car: 2019 Stinger GT1 AWD
Default Log w/ pulls on map 2, 3 and 5 - check please. - 09-10-2021, 07:51 PM
Turboencabulator from Stingerforum here -
An update it looks like it was a fuel wire that was causing all my issues. (so happy to have finally sorted it) Trims are mirrored now and not deviating. Pulls all the way now.
Mods:
K&N Intakes
BMS Catch Can
Denso 5346 Plugs Gapped @ 0.022" (fresh set)
JB4 w/ Fuel & EWG wires.
I did a few pulls this evening First big pull on the log is Map 2, 2nd big pull is map 3. 3rd short pull from a dig is map 5.
Car had 7/8 tank of Shell 93 + 2 caps of boostane professional.
I plotted the CSV on DataZap
I pushed the EWG settings back to default recommended from the EWG thread
Duty @ 50 across the board
FF@ 50
Pid Gain @ 20
Shift reduction at 60.
Thanks for taking the time to review the log.
2019 Stinger GT1 AWD - K&N Intakes, JB4 w/ Fuel & EWG wires, BMS Catch Can.
Default 09-12-2021, 09:28 PM
Runs look good to me. Leave FUA = 0 as I've become used to reading these logs that way now.
I don't see any issues with map5 although that is the shortest run there. If it looks like this map3 run during a longer pull then its good to go.
