rcareen rcareen is offline
Car: 2020 Kia Stinger GT
Default Map 1 Log Check - 09-06-2021, 03:12 PM
Hey, I was wondering if I could have someone take a look at my map 1 log? Thanks in advance!!
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 09-07-2021, 07:20 AM
What mods? What fuel? What plugs?
Log looks OK but there are a few timing correction I think can be cleaned up with a higher octane or some E-85 mix. (or better plugs depending on what you have in now)
Default 09-07-2021, 07:44 AM
Iíve only got a muffler delete and intakes. Iíve only got access to 91 here in Newfoundland and Iím using the Costco top tier 91. Iíve got the HKS plugs that were pre-gapped to .028, I was wondering if I should take them out and close in the gap?
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 09-07-2021, 08:11 AM
Absolutely pull those out. Never trust "pre gapped" lol. I guarantee those are waaaay off. Get a good feeler gauge and put them between .022 and .026
Default 09-07-2021, 08:28 AM
Oh they are all at .028, I manually checked them all before installing them with a gauge! Should I close the gap on them all?
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 09-07-2021, 08:31 AM
Yes, close them .022-.023 will be fine even if you stay Map1, it will give you room incase you get some octane boost or go methanol.
Default 09-07-2021, 08:42 AM
Sounds good! Thanks for the help by the way! Iíll get those closed later and do a Map 2 run and post it!
