1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 08-10-2021, 04:41 PM
3d print��
2021 kia K5GT.
Jesse2321 Jesse2321 is offline
Car: Hyundai Sonata n line
Default 08-10-2021, 05:02 PM
Originally Posted by 1st timer
3d print��
True I have mine zipped tied pretty well so there not moving so I donít mind waiting
G70in21 G70in21 is offline
Car: 2022 G70
Default 08-24-2021, 02:44 PM
Watching thread for our 2.5 sante fe... lol
'22 G70 3.3T Havanna Red
Currently...stock
CTrink CTrink is offline
Car: '21 Kia Sorento SX AWD 2.5T
Default 08-30-2021, 09:34 AM
Sub'd! Out for delivery as I type.
2021 Sorento 2.5T
Default 08-30-2021, 02:36 PM
Pretty simple/straightforward install. Running my tank out now to go get some 93. Also; pretty slick temporary front emblem while I'm waiting on new overlays:
Name:  burger - Copy.jpg
2021 Sorento 2.5T
Default 08-30-2021, 07:16 PM
Nice!
Default 08-30-2021, 07:33 PM
Nice!
Thanks Terry. My BMS Powerbox on my e90 330i was awesome and proved the quality of Burger. This install was cake compared to that. No splicing or dicing. Im nervous on the three pin female connector though. There isnít a possible way to zip tie it on the Sorento. Itís hell getting down there. My Shark BOV was worse to install, but if I realized the MAP connector was down there also I would have done it all at once.
2021 Sorento 2.5T
Default 08-31-2021, 11:39 AM
Does anyone know the stock sparkplug gap?
2021 Sorento 2.5T
Default 09-01-2021, 02:17 PM
BETA 2.5t and 3.5t JB4 system available here: https://burgertuning.com/collections...and-3-5l-turbo
Was able to track down a local 2021 Genesis GV80 2.5L today for a little long overdue JB4 development and dyno testing! This engine uses the same connector system as the new 3.5L, both of which will share a new JB4 2.5/3.5 harness variant.
Anyway, the 2.5L is pretty stout and responded really well to extra boost. Vehicle is 100% factory (factory plug gap too) and we did a few runs on 91 octane (didn't want to really push it on 91 since we were just borrowing it), and then added in a couple gallons of E85 for E20+91 testing which should be fairly similar to 93 octane. Result was a gain of around 65whp and 79wtq! I have no doubt once we spend a little more time with the tuning, add an intake, go up to E30, etc, this little power plant will see 350whp.
We will be adding BETA systems to our site shortly and will make another post talking about the connectors we're using that aren't quite right but good enough for the moment.
Is there a proper listing of each Map and the recommendations to run them for this tune?
In my JB4 mobile app I have access to 4 maps: 0 (disabled), 1 (+2.5psi), 2 (+4psi), 3 (+5psi), and 6 (custom). However; in post #1 you mention using Map 4. I'm currently running the "20 - Kia/Genesis SmartStream 1.6L & 2.5L" platform.
2021 Sorento 2.5T
jaddi85 jaddi85 is offline
Car: Kia Stinger
Default 09-06-2021, 12:03 PM
I with you one this about the connectors. Not much room to properly secure in my Sonata N Line. The MAP sensor kept on coming out with any movement of the harness.
@BMS - any idea on when the new connectors will be available? At least for the 3 prong MAP?
