(#26)
Default 03-29-2021, 10:47 AM
Looks fine but your boost target is higher than what your turbo can deliver, WGDC is maxed out so you're as good as its going to get at this point.
Bullyking Bullyking is offline
Car: 2013 535i
Default 03-29-2021, 12:42 PM
I thought stock turbo could handle 20 max ?but I am pleased with the psi Also is there an adjustment for wgdc ? What other mods could I get to get some more power? Iím a little throttle happy and love this car would next step to be to just go stage 2 turbo? Or p/I e85 ? Also is xhp stage 3 a good mod for trans and worth the 360? Sorry for all the questions new to
The whole tuning era
2013 535i n55 c/dp, bms intake , Jb4, MHD pwg2 e85 bef ngk 2step cooler plugs walbro 450 lpfp e40
Default 03-30-2021, 09:24 AM
Next step is a PS2 and upgrade fueling.
Not much else you can do for a maxed out turbo.
Car: 2013 535i
Talking 03-30-2021, 09:42 AM
Which one should I go with send a link pls
Car: 2013 535i
Default 05-13-2021, 12:07 AM
Map 6 log with 5gal of e85 added to 92oct somebody please review log and let me know how itís looking
435gc 435gc is offline
Default 05-13-2021, 05:26 AM
As said above. Looks fine except you are at maxed wgdc. You are pushing the turbo to its absolute limit. You will not be able to do that for very long before your turbo breaks down.
You need to reduce your boost targets or get a new turbo.
Car: 2013 535i
Default 05-13-2021, 07:22 AM
Any way to adjust wgdc ?
Default 05-13-2021, 07:31 AM
Yes, in your case you either need to check for a boost leak and fix, or if there is no leak you would need to lower boost. Or get a bigger turbo.
Car: 2013 535i
Default 05-13-2021, 07:46 AM
Okay I’m getting my vrsf fmic today so I’ll check if anything seems to be leaking what’s the best way to check for boost leak
Car: 2013 535i
Default 05-13-2021, 07:48 AM
And I’m guessing ps2 ?
Default 05-13-2021, 08:42 AM
Smoke/pressure test is the best way to check for leaks. Chargepipe and fmic connections are the common trouble spots.
Ps2 is a great option. There are others with higher price tags.
Car: 2013 535i
Default 05-13-2021, 08:43 AM
Going to do a pressure test before I install intercooler to see if I have any leaks
Car: 2013 535i
Default 05-16-2021, 12:28 PM
Pressure test was good no leaks at all how are people running 20psi on stock turbos ? I have read that the 535i turbo is absolute max of 25psi
Default 05-16-2021, 01:01 PM
I've never heard of that high a boost pressure produced from a stock pwg turbo. On ewg I have.
Regardless, your turbo is not up to it it seems. I would think it would be doing better than it is. Do you have upgraded intercooler and highflow d pipe? May be some loss due to back pressure.
Or it could be that you've got an 8 year old turbo and its just not up to the task you're asking of it. Likely time for ps2.
Car: 2013 535i
Default 05-16-2021, 08:02 PM
Yes 5” vrsf intercooler and vrsf c less dp only exhaust still on car is the resonator
Car: 2013 535i
Default 06-12-2021, 07:02 PM
Need help ASAP tryed to update to alpha firmware and didnít connect now car is not starting stuck in a parking lot
Default 06-12-2021, 11:13 PM
You should be able to reload the firmware or revert to the next earlier version.
