(#276)
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 07-25-2020, 09:24 PM
Seems OK. If codes return will need a 2580 update.
No more codes yet, but tonight it was underboosting in a way. Could hear turbos spooling, dumping boost, etc., car running normally in every way but building much lower than normal boost. Will try to get some logs tomorrow.
Default 07-28-2020, 05:07 AM
Codes have returned. Will try to get some logs tonight.
Boelli134 Boelli134 is offline
Car: Stinger gt 3.3T
Default 07-28-2020, 11:03 AM
I have ordered today the EWG connectors.
I have a question.
Which map use it?
Map 6?
Oder can i use Map 3 oder a other map?
Default 07-28-2020, 02:42 PM
The same map guide applies whether you add EWG or not.
Default 07-28-2020, 02:51 PM
Okay thanks!
Have you read the other thread because my Problem After the Update to V17?
Default 07-28-2020, 02:53 PM
mitchyboy mitchyboy is offline
Car: Kia Stinger GT
Default 07-29-2020, 05:45 PM
Originally Posted by mitchyboy
Got the EWG wires running fine wiithout codes
Can you please check the attached log and see what you think?
Please...
Default 07-29-2020, 08:01 PM
Please...
So far looks good but let's go for a longer run!
riverflow riverflow is offline
Car: Genesis G90
Default 08-02-2020, 05:02 AM
hi, I installed JB4 to genesis G90 3.3t with ewg cable. mods are K&N panel intake, IKH27 denso plug 0.022', fuel wire. RON 100 fuel. no meths kit and stock exhaust. I switched on bit 3. and FF was 55. in map 6 (I made similar to boost additive 75 on meths setting) I ran several times with dragy and I had limp home mode. (pedal 100, but throttle 35) no codes show up. what is the problem? recently I've experienced same with changed map6 (max boost 6.8psi at 6000, FF=50) overboost not shown. Is this phenomenon related to exhaust temperature or bit3 on (now I turned off bit3)? no codes showed up.
ACArduino ACArduino is offline
Car: Kia Stinger GT
Default 08-02-2020, 10:08 PM
New to the JB4 and forums, but recently installed the EWG wires on my Stinger GT. Attached a few short Map 2 runs and an idle, and thoughts? Aside from driver error...
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default 08-21-2020, 08:55 AM
Connected and have huge issues. Car barely runs, in choppy limp mode. Getting codes ranging from misfires to turbo sensors. I double checked all connections and everything is good. I had even ordered a new chip just in case and swapped that out (and updated firmware). Same problem. I disconnected jb4 and runs fine in stock form. Help!
Default 08-21-2020, 09:00 AM
Sounds like something is installed wrong then. Post up some photos if you want us to help you diagnose it.
Default 08-21-2020, 09:25 AM
Driver side is hooked up to 8/14
Default 08-21-2020, 09:26 AM
Reg wires are still hooked up at sensors. They must be hooked up right since the car runs with jb4 unplugged
Default 08-21-2020, 09:41 AM
Update - took for a drive, still getting turbo sensor issues and no turbo working. Probably since still connected to powered off jb4 I think?
Default 08-21-2020, 09:56 AM
Another update (sorry) - cleared codes and they didnít come back. Turcos are working but car still feels sluggish. Might be because I am used to map 2
Default 08-21-2020, 10:05 AM
Codes are back
stock_stinger stock_stinger is offline
Car: 2019 STINGER
Default 08-29-2020, 06:04 PM
are you sure you have passenger and driver wires not mixed up?
Pharmin2006 Pharmin2006 is offline
Car: Kia Stinger GT2
Default Car way off after EWG wires - 08-30-2020, 12:08 PM
I have been running JB4 w/ fueling wires for a few weeks up to and including Map 3 on 93 octane + VP Ocatainium. Car has ran really good with these changes and JBL down *****. Installed the EWG wires this morning and something is way off. I would really appreciate any help.
djerickd djerickd is offline
Car: 2019 GTS
Default 09-02-2020, 09:52 PM
You fix it?
Default 09-03-2020, 05:19 AM
I think it’s fixed. I’ve had the JB4 kit for about a year and finally got around to doing plugs and install. I was on firmware version 9 so that was the hiccup. I have the fuel-it kit but not sure if I’m going to install it, I’m not a tuner and help with this problem was slow at best.
Car: 2019 GTS
Default 09-03-2020, 07:22 AM
The fuel it kit is super easy to get going
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 09-27-2020, 11:25 AM
Hey Terry, log check.
Map 5, 93oct with meth.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Car: Stinger 3.3T
Default 10-03-2020, 09:48 AM
Yay, nay?
Default 10-03-2020, 11:11 AM
Looks fine to me!
