(#1626)
Allmanb Allmanb is offline
Car: Kia Stinger GT
Default 02-06-2019, 02:54 PM
We just put a prototype BMS Stinger IC on our development car.
All maps will take advantage of it but should have some better upgraded IC metrics soon.
Any numbers on the iat drop in temps? I know mine would heat soak bad at the track.
2018 Stinger GT AWD
JB4 w/ Fuel control wires
Denso plugs .025 gap
K&N air filters
Default 02-06-2019, 03:19 PM
Will be posting data in the near future.
Default 02-06-2019, 03:39 PM
Can I post a teaser picture?
Default 02-06-2019, 08:56 PM
No.
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 02-07-2019, 12:38 PM
Awesome news, your cores for other platforms look great and are priced super well. How about catch can(s)?
Default 02-07-2019, 12:47 PM
It's being worked on.
Default 02-07-2019, 10:47 PM
Quick run from tonight as it's nice and cold, 45F! Car is on a half tank of E40 and I ran map2 (no WMI), car is on the stock rims/tires, has our prototype intercooler, and a new suspension modification we're testing.
Hauling ass for such low boost! Tried a run on map3 and was able to get high fuel pressure to start dropping so definitely time to get back to work on fueling upgrades.
Default 02-08-2019, 05:49 AM
Got any plans for a different set of wheels / tires? I got my set of Forgestar CF5V last week but weather isn't good enough to go back to summer tires yet.... <20lbs front 19x8.5 and <24lbs rear 19x10, although the 295 I'm throwing on the rear probably offsets that weight savings lol
Default 02-08-2019, 09:13 AM
I like the 18" RPF1's for racing but they are kinda ugly. For the short term I'm going to stay on the stock rims/tires which look good, are just heavy as hell. Looks like the weight savings on the RPF1 18" rims/tires is worth around 1mph in my testing.
Bourgeoisx Bourgeoisx is offline
Car: Stinger GT
Default 02-08-2019, 02:19 PM
Post a log on map2 and let's see how timing looks now, and go from there.
No setting changes are required for v7.
Terry, will this work?
Default 02-08-2019, 02:30 PM
It's not showing extended cyl 2-6 timing data for some reason, but based on what I can see log looks fine to me.
Car: Stinger GT
Default 02-08-2019, 02:54 PM
What data should i be able to see on the app gauges? 2-6 never show any movement and oil temp stays at zero.
Also, will map 3 work with just 93 gas?
Default 02-08-2019, 03:04 PM
Oil temp isn't active yet. But your vehicle may have different ECU software though if cyl 2-6 isn't showing up. Cyl1 is good enough to evaluate but generally speaking for 93 octane I'd stay on map2. It's a great all around map.
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default 02-08-2019, 04:31 PM
I want that intercooler!!!!
Any idea on when they might be ready/price?
Default 02-08-2019, 04:33 PM
Still too early to give specifics, sorry. We're working on it. Compared to the other offerings I think you guys will find it offers some unique features that give it a leg up. And our prices are always good.
Default 02-09-2019, 06:10 PM
For codes you'd clear ign on, engine off. If they don't clear then something is still wrong that needs to be corrected.
Default 02-09-2019, 08:40 PM
Just full throttle runs are good, on a safe private track, of course!
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 02-10-2019, 08:45 AM
Is it normal for the Tail BOV to stay open when the car is turned off?
Seems to happen every time.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Snared Snared is offline
Car: 2018 Kia Stinger
Default 02-10-2019, 01:54 PM
Hey Terry.
Yesterday I upgraded from. V5 to V8. At first all seemed good. Today I have noticed a couple times that I am not making any boost (43_33csv). I was on the highway try to pass someone and nothing. I got off the highway and tried to do a pull and no boost. Still in Map 2 and no codes.
Default 02-10-2019, 02:21 PM
Originally Posted by Snared
Hey Terry.
Have a longer run on map2 so I can check it out?
Default 02-10-2019, 02:53 PM
The initial attempt to upgrade to the newer version failed and it increased the timeout and it was successful the second d time.
Before I tried to get a longer run I changed it to Map 0 and drove it for a couple minutes then changed it back to Map 2.
I keep running out of room trying to get a long test. Hope these are better. 29_30 was getting onto the highway and 32_14 was passing (this time boost kicked in )
Default 02-10-2019, 02:59 PM
These look normal, if the no boost issue comes back we can look in to it further.
Car: Stinger 3.3T
Default 02-11-2019, 12:51 PM
Anything on this?
Default 02-11-2019, 03:17 PM
Anything on this?
Yes, normal.
KLR STINGER KLR STINGER is offline
Car: Stinger
Default 02-12-2019, 02:12 PM
Anything on this?
Depending on Spring used that is normal. In fact some spring combinations open at idle is even normal. I like to run the minimal amount of spring pressure to ensure valve is just barely closed at idle. Once under boost the pressure behind the diaphram keeps closed shut, but a lighter spring rate will allow for faster response.
