(#1201)
Car: Stinger
Default 12-16-2018, 12:44 PM
I'd be fine with that. Still give customization through FUD. I'll be heading out shortly for a few runs to log.
Vroomz Vroomz is offline
Car: Kia Stinger
Default 12-16-2018, 01:14 PM
There is no way for the system to tell whether fuel lines are installed and automatically do this?
I would think having the AFR wrong for noob customers is only going to cause you problems if they skip the step, and may even lead to uninformed FUD.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 12-16-2018, 01:49 PM
For v7 firmware working on a cool new double-PID fuel control algorithm, nice improvement in AFR control over the single offset algorithm we're using now. Fuel enrichment is bias for bank1, and I plugged bias for bank2 under "calc tq" for now.
Did a bunch of testing this AM and so far, so good. If anyone has time to run a few logs today I left the test firmware in this post. This specific firmware changes the fuel control logic, for it to work right you'll want to set ALL fuel bias values to 80.
I also made an adjustment to the passive delete function which some have reported causes a "pause" during startup. For those using it let me know if it corrects the pause.
*** EDIT have enough out there to get some data in. Will repost in the first post once we know it's solid ***
Hey Terry, I don't see the "calc tq" on my list of data points. Amy reason why?
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
Default 12-16-2018, 02:04 PM
The column might be called dutycycle in the CSV, I view in the app or windows interface and we renamed that column calc-tq awhile back.
Default 12-16-2018, 02:16 PM
Added the v7 BETA to the first post along with the interface changes and updated notes to get a wider range of test data. Once we know it's all solid we'll remove the "BETA" tag from the firmware.
Default 12-16-2018, 07:39 PM
I guess everyone testing v7 was arrested for speeding and is spending the night in jail instead of sharing logs?
Car: Kia Stinger
Default 12-16-2018, 07:51 PM
Trying to figure out how to upload a file. Got a couple lower gear pulls. Was raining ALL DAY so I couldn't get anything great.
Added the only multiple gear pull I got.
Car: Stinger
Default 12-16-2018, 08:03 PM
Here are a few from earlier. Feels pretty good. I did get a p0400 error Tonight though. I cleared and will let you know if it comes back.
Default 12-16-2018, 09:15 PM
p0400, exhaust gas recirc valve? Not sure how that could be tuning related. Ever gotten it before?
Default 12-16-2018, 09:17 PM
Thx!
Car: Stinger
Default 12-16-2018, 09:18 PM
I know.. Makes no sense. Especially since there is no EGR on this car unless it's internal to the head
Default 12-16-2018, 09:40 PM
We'll see if any other reports of it turn up. Maybe related to your exhaust mods? If hunting codes may want to turn passive delete off.
I made a change to passive delete in v7 that may prevent it from working in some situations. We'll have to keep an eye on that too.
Car: Stinger
Default 12-16-2018, 09:43 PM
Thoughts on the logs Terry?
Default 12-16-2018, 10:27 PM
They are OK but some areas that need improvement. With the really cold weather and exhaust mods you're a special case, you'll need the IAT spoofing wire to get things better sorted in this cold weather I think. We can pick it up via email when you have it.
Default 12-16-2018, 10:29 PM
Hit the private track for a few runs on the new v7 fuel control. Overall pleased to report it works well. Was able to set a new personal best.
Same mods as always: JB4, BMS intake, BMS WMI (50/50 mix), Enkei RPF1 18" rims w/ 555R tires, E30.
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 12-17-2018, 06:39 AM
<11.91 run @ 121mph>
drumma022 drumma022 is offline
Car: 2016 340i
Default 12-17-2018, 07:30 AM
Wish I would've checked this thread over the weekend.
Here is a quick run this morning. Still 1/2 tank of E30-ish. I didn't change any settings, just uploaded v7 beta and go.
Default 12-17-2018, 08:35 AM
Wow that looks smooth.
Default 12-17-2018, 08:43 AM
Looks solid to me!
crewdawg130 crewdawg130 is offline
Car: 07 335i e90
Default 12-17-2018, 09:00 AM
Any way we can make an new WMI thread under Kia?
Adamdan Adamdan is offline
Car: Stinger
Default 12-17-2018, 09:04 AM
Looks solid to me!
The afr looks so flat and stable now. Itís that because of the new programming in v7?
Metalmania82 Metalmania82 is offline
Car: Stinger GT
What's the spoofing wire?
Default 12-17-2018, 09:09 AM
Yes, v7 dynamic fuel control FTW.
Default 12-17-2018, 09:10 AM
It's an add on wire to the JB4 harness we're experimenting with that lets it adjust the IAT, originally was testing it for timing control but found it's more useful in situations where we need to increase the flash target. Like really cold weather, with primary *** deletes. For now it's just an experimental thing I'm testing with a couple customers.
Sure I'll make one shortly!
Tyson.Anderson
