Jtm340 Jtm340 is offline
Car: 2021 bmw g20 m340xi
Default 2021 m340 test log map 2 - 11-18-2021, 11:43 PM
So this is my first log with the jb4. Was on my way home from work which isn’t the best route for a log but did my best if need be I will redo otherwise just want to see how things are running and if adjustments have to be made. Only mods are billet intake and awe non resonated touring exhaust along with jb4. Ewg is connected as well. Plan on running e30 or e40 soon but want to up power as much as possible till then. Please let me kno if new log is necessary might have let up at end due to traffic
Default 11-18-2021, 11:55 PM
Sorry….only running 93 octane from day 1. Never seen any other fuels
Car: Evo VIII
Default 11-19-2021, 10:46 AM
Timing corrections came in hot when you lifted the pedal a bit then got back into it. Please get a log in 3rd or 4th gear from 2k to redline on a safe private track. Thanks!
Default 11-19-2021, 12:04 PM
Should I stay in map2 or switch to map1
Default 11-20-2021, 06:24 PM
Because of the timing problem was told to do some logs in map 0 to see how it’s running stock. Please review and let me kno what I should do next please
Car: Evo VIII
Default 11-22-2021, 01:29 PM
Seems a bit strange. Have you ran octane booster in the past? Check your spark plugs to make sure they still look good. I have linked NGK plugs below.
https://burgertuning.com/products/ng...31001746899059
Default 11-22-2021, 04:56 PM
Sorry this is new msg and not reply. I don’t kno why but couldn’t send you logs when I was trying to reply. Anyway mods:2021 bmw m340
BMS billet intake
AWE non resonated touring exhaust
Jb4 w/EWG SENSOR connected……always have put 93 octane fuel but changed stations for my recent tank after ALDO recommended too because of timing issue. So I’m not sure if the logs I already sent you were the new gas but the logs with this msg definitely are. The change was Valero switched to Sunoco both 93. I never used octane booster but since my msg. To you aldo has mentioned using some booster maybe. As far as spark plugs I can have them checked but I took delivery of my car last October. Installed jb4 2 weeks ago. They can go bad that quick. Anyway the plugs you sent are upgrades I’m guessing. I’ll def have them checked but do you think I should get them anyway. Ok…..thank you so much for looking at this for me. Sent you stock logs after switched gas stations and also map1 logs. Thank you
