Arron280 Arron280 is offline
Car: Cupra 280
Default Best map 6 settings for a cupra 280? Jb1 - 07-05-2019, 07:04 AM
Anyone here managed to find the best settings and could they post them, thanks
FeldiSan FeldiSan is offline
Car: VW Golf 7 R
Default 07-10-2019, 12:03 AM
Hallo,
Every Car is different in thare Handling with the Mappings. The maps there works fine on all cars is the map 1 and 2. For map 6 you musst develop in coworks with the log funktion. Not every engine ist the same.
In the gen3 thread is a example for starting the developing the map 6 from George.. This is the starting point at you can starting the development from map 6.
My first intention wehre to locate the fol with the base map 6 from George. My Golf R have a maximum Fol of 45-48 other cars like up to 60. When you go to Low Fol with too much boost you have the afr too lean. The JB4 rescue your Engine yes, but truly not good for this too!
The best way is, chance boost little bit up an then drive. Look at the timings, afr and the trim. All dicriptions are in this Forum, this help you :-)
Greetings from GER
Default 07-10-2019, 08:44 AM
Post a current log on any other map so we can guide you. Don't forget to post your mods and fuel used too!
