Enfiftyfore's Avatar
Enfiftyfore Enfiftyfore is offline
Car: 2009 135i
Default 135 on EC7's - 11-03-2015, 03:28 PM
I have some APEX EC7's which are:
18x8.5 ET45
18X9.5 ET58
I want to run 235/40 265/35 Nitto NT05 or RE-11's. Will I need camber plates? I plan on getting the M3 control arms later on. I'm on factory suspension.
alexc93 alexc93 is offline
Car: 6mt N55 135i
Default 12-15-2015, 09:25 AM
On factory suspension I can't see why you would need camber plates with that setup. Should fit perfectly!
2014 M235i Black Sapphire Metallic / Black Dakota Leather
|| 30% Llumar CTX || IND Painted Front Reflectors || BMW Performance Grilles || Lightweight Front Lip || BMS Exhaust Tips || JB4 || ER Charge Pipe || MPI ** ||
N54VLAD N54VLAD is offline
Car: 09 BMW 135i
Default 05-15-2016, 11:29 AM
18x8.5 ET45
18X9.5 ET58
I ordered the same setup, mine is just on back order. My car is lowered so I'm probably going to have to get camber plates. I also want to run the same front and back setup. A square setup would be preferred but you know how these cars are with wheel fitment.
baja2700 baja2700 is offline
Default 05-16-2016, 03:14 PM
im looking at getting the same tires, do we think that the 35 rear side wall vs 40 front sidewall will fit fine?
