JPSlick's Avatar
JPSlick JPSlick is offline
Holla
Car: 2009 335i 6MT
Default 03-09-2010, 12:56 PM
Originally Posted by shoes
Yes I've noticed.
It's been through numerous car washes and rain driving - no problems.
The USB cap I have on it works perfect, but it wouldn't recommend this spot without one.
Just for throwing ideas out there, You guys know that rubber flap that goes over the ECU, that where I have the USB. Fairly safe IMO.
ktmsmr12's Avatar
ktmsmr12 ktmsmr12 is offline
Default 03-28-2010, 02:34 PM
bimmer335i07... Thanks for the DIY. Very easy, following your instructions and pictures. I think I may just tuck the USB cable under the top of the floormat and put my netbook in the passenger floorboard when logging. Of course it literally just started raining the minute I finished, so I guess I will update from my current 2/17/10 firmware and log on the way to work tomorrow.
Thanks again.
Mike
bimmer335i07 bimmer335i07 is offline
Default 03-31-2010, 07:02 PM
Thanks again.
Mike
You're welcome! Glad it helped!
JB3 2.0 map 7
SLEEPYDUB's Avatar
SLEEPYDUB SLEEPYDUB is offline
Call da Ambalamps
Car: 621whp/600tq MK4 Jetta and 135i
Default 04-06-2010, 03:43 PM
Quick question, is this the same way to install it on 135i's as well?
SLEEPYDUB's Avatar
Call da Ambalamps
Default 04-08-2010, 10:30 AM
Answered my own question, yes its the same, and its easy as hell
My 135 My 135 is offline
Car: BMW 135i Coupe
Default 04-12-2010, 01:33 PM
03-02-2010, 05:21 PM
I was able to do it without unpluging any of the harness....just pull al lthose grommets up...unclip the whole bracket at the rear of the compartment behind the ecu and lift everything up and forward....easy to get to that hole.
Where did you unclip the whole bracket and lift everything up? Please show me how by referring to one of the photos above. Thanks.
philipf22 philipf22 is offline
Default 04-24-2010, 07:16 PM
Originally Posted by Darkcyd335xi
When I saw the DIY for how the Proceed guys' ran theirs, I knew I could get to the hole in the ECU box by just pulling out the DME. You obviously wont see the quarter size hole like you do when everything is removed, but you CAN see it so you know where to feed the usb. I'm just a real big lazy a$$ sometimes so I wanted to do it with the least amount of work involved.
If you're installing your JB3, takes an extra 5-10 minutes to route through and into the glove box.
I searched around but I was unable to find this link. I'd prefer to make this job as easy as possible without having to remove everything. Does anybody have the DIY for the proceed referenced here? I just want to check it for the pics.
Default 04-24-2010, 07:24 PM
I think I found it:
http://www.e90post.com/forums/showthread.php?t=65147
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 05-01-2010, 02:29 PM
Damn that was easy! Thanks!
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 05-10-2010, 05:59 AM
Originally Posted by bimmer335i07
If you need help installing your JB3, let me know. I live in Union, NJ.
Thanks for the great post on. Do you think the cable can be passed thru without removing the ECU? Perhaps with a very long needle nose pliers to push the USB end thru? I tried fishing thru with a bent snake & wire from above couldn't get it thru the firewall. I'm just nervous about emptying the whole box.
Default 05-17-2010, 08:01 PM
Just did another install yesterday. You actually don't need to remove everything. Just remove the divider/sleeve (not sure what you call it) closest to the cabin. Basically, just pull the tab (RED) in the pic below and pull out that sleeve/divider. That should give you enough room to stick the USB cable down the hole. Remember, you don't need to force the USB, just stick it through a little and it will come out in the cabin.
GL!
JB3 2.0 map 7
Vroom's Avatar
Car: 335i 318ti
Default 05-18-2010, 04:50 PM
GL!
Thanks for taking the time to post the picture. Did you remove the divider so the cable can be fed horizontally thru the hole vs. on a downward angle? I'll tackle this in a few weeks when I have some time & will be sure to post some pics.
Default 05-18-2010, 05:02 PM
Yes, by removing that 1 divider (leaving all wires plugged in), that will give you enough room to feed the USB cable down horizontally through the hole.
JB3 2.0 map 7
Vroom's Avatar
Car: 335i 318ti
Default 05-18-2010, 05:04 PM
Sweet! Thanks again!
jomamma jomamma is offline
Car: What else?
Default +1 that's how I do it too... - 05-19-2010, 09:13 PM
Yes I've noticed.
mnst3r's Avatar
mnst3r mnst3r is offline
Car: 09 135i 6MT
Send a message via Yahoo to mnst3r
Default 06-13-2010, 02:18 AM
Thanks for the DIY post, it was very simple to follow.
Just wanted to add that on my install, I ended up using a T15 torx for my 2 screws holding the panel under the glovebox. Other than that everything else was spot on exact. BTW the pics helped out alot.
09 135i 6MT JB4, DCI, CM MethKit, Stett CP w/ Tial bov, MT ST ET, CPE **'s and Axleback Exhaust
12.07@ 113.94 1.7 60' on 9/03/11 "Fastest 135i in Alaska"
Vroom's Avatar
Car: 335i 318ti
Default 06-13-2010, 07:05 AM
IF YOU HAVE NOT DONE THIS YET: Here's a WARNING to those of you who are always trying to find a faster & easier way to do something. Due to an extreme fear of yanking the ECU I tried fishing the cable thru the hole that is visible as soon as you remove the ECU box cover. NOTE: this hole goes to a small fan on the interior of the car and is the WRONG hole! You can even fish a snake thru this hole into the interior, but will not be able to get the USB cable thru it. After wasting about 5 hours on 2 separate attempts I went to a penskeparts diagram to see that I was fighting the wrong battle. I was able to get a very minor win. By removing the grommets, lifting the removable ECU carrier about 1/2" and fishing one of my half dozen snakes from the interior to the ECU box, I pulled the cable back into the interior w/o removing the ECU. If I had to pay a dollar a curse word, I’d be broke.
MITE82's Avatar
MITE82 MITE82 is offline
Car: 08 135i
Default 08-04-2010, 11:15 PM
One thing that i really want to know is ,,, do u really need to unplug the battery ?? cuz wouldn't it reset all the electronic settings in the car like radio and etc.
txsailor's Avatar
txsailor txsailor is offline
Flame Thrower
Car: 335xi 6MT
Default 08-05-2010, 08:53 AM
no
MITE82's Avatar
Car: 08 135i
Default 08-05-2010, 09:39 AM
That's what I thought .. How about dealer visit? Can it be left in or would be a good idea to take it out before hand ?
MITE82's Avatar
Car: 08 135i
Default 09-20-2010, 09:42 PM
cant wait to try this later this week
Vroom's Avatar
Car: 335i 318ti
Default 09-21-2010, 05:26 AM
No if you are not disconnecting the ECU. If you are going to empty the box, I would follow the sticky & disconnect the battery.
txsailor's Avatar
Flame Thrower
Car: 335xi 6MT
Default 09-21-2010, 07:30 AM
when in doubt- take it out. It doesn't take long after you have done it a time or two- maybe 20 minutes.
MITE82's Avatar
Car: 08 135i
Default 09-21-2010, 08:08 AM
this sound familar some how .... I was short on time yesterday when i was installing the JB3 so I didnt get to do the USB setup ... will try agian this week sometime... thanks and yes when i'm in doubt I always take it out
VictorFranko VictorFranko is offline
Default 10-30-2010, 07:42 PM
The pictures were a great help making this DIY fairly straightforward but I'm surprised no one has mentioned what to me was the hardest part, namely having enough space to jam the JB3 with the adapter cable attached inside the ECU box. It's a pretty tight fit and requires some careful repositioning before everything is buttoned up.
