Oner Oner is offline
Car: N55 BMW 135i
Default Map 6 - 01-18-2019, 11:44 PM
Sorry for the last post guys just learned how to post this . Please review this log and tell me your input ! Thanks in advance.
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 01-19-2019, 06:32 AM
Looks prety good to me trims are right where they should be maybe add 2 ta 3 points in the pi fuel bias around 4000 - 5000 just to tweak that mild spike in trims when you first get on it. Other then that looks pretty good.
'14 435I RWD MHD/JB4 "Twisted Custom BEF" ° XHP Trans Tune ° GFB DV+ ° Rev9 FMIC ° VRSF CP ° BMS Intake ° HP Down pipe ° Borla ATAK Exhaust ° Stage 2 LPFP ° BMP PI ° BMS PI controller ° EWG Harness Upgrade ° e85 ° 3.5 TMAP ° NGK 5992 Plugs "0.020"
Car: N55 BMW 135i
Thumbs up 01-19-2019, 11:46 AM
Thank you. I will adjust
drwillb drwillb is offline
Car: 2012 n55 135i
Default 01-19-2019, 12:43 PM
Oner, what are your mods? I see your target boost is 24psi and you can hold it easily. I'm going to assume PS2 or equivalent.
I've got a PS1 2012 135i so just want to compare.
Car: N55 BMW 135i
Default 01-19-2019, 01:41 PM
What about this one ? Plz check and let me know
Car: N55 BMW 135i
Pure stage 2 yeah
Phataxe's Avatar
Car: 2014 435I
Default 01-19-2019, 02:29 PM
That looks pretty solid bud..How does it feel? maybe increase duty bias for Wastegate at 4k thru 4500 up by 2 And Fuel_bias 5500 up by 1 point.
Phataxe's Avatar
Car: 2014 435I
Default 01-19-2019, 02:41 PM
It's Hard to know for sure Maybe throw up like 3 logs as conditions change a bit each run. but i think with above conditions that would be the only tweaks i would try. Log looks pretty good over all though
Default 01-20-2019, 02:49 PM
Originally Posted by Oner
Pure stage 2 yeah
What fuel?
Can we see a better 3rd gear pull?
2k - redline & shift into 4th.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: N55 BMW 135i
Default 01-21-2019, 01:31 PM
What fuel?
E55 ok here’s the other log
Car: N55 BMW 135i
Default 01-21-2019, 06:42 PM
Bump
Phataxe's Avatar
Car: 2014 435I
Default 01-21-2019, 10:06 PM
Maybe try from 4000 - 6000 Duty bias reduce by 1 point. Looks pretty good over all though. Thats just a minor tweak to try. If you under boost and dont hit right on target i'd return it to where you are.. Your over boost is pretty minor.
Car: N55 BMW 135i
Default 01-22-2019, 01:56 AM
Thanks for the feedback
What do you think Dave
Default 01-22-2019, 12:38 PM
You could try reducing your DB Settings by 3 from 4.5k to redline.
That may bring u a bit closer up top, but this looks pretty solid- def working the turbo hard..personally id lower boost a little up top in general, but that’s a personal pref.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: N55 BMW 135i
Default 01-22-2019, 01:48 PM
What would you recommend me lowering it to ? Do you think for the stage 2 pure turbo this is endangering it? Love the feedback guys
Default 01-23-2019, 11:17 PM
I don’t think you are putting it in any “danger” I’m assuming you aren’t going WOT to redline daily, multiple times a day.
If it were me, I’d maybe drop it down to 23-24 psi across the board- i don’t think you’ll see much of a performance drop, and it would stress the turbo a bit less.
e92 AT 335xi 2.0
Doc Race Kit 6062
