E92Tony E92Tony is offline
Car: 2007 335i Dinan s3
Default N54 2007 335i coupe ticking noise - 01-07-2019, 04:05 PM
Hey guys I just bought this 2007 with 94000 miles and it's a MT. Does anyone know what this ticking noise is it started on my way back home. It is constant but when coming of the gas you can really hear it. 2007 335i N54 ticking noise - YouTube
I already know it needs new spark plugs since on the drive back the throttle became choppy and the guy said it needed new ones my ses light is on as well. It's dinan stage 3 and my creator BMW obd2 reader wouldnt even give the options to read for engine codes is this because of the tune.
Sorry if it's confusing this is my first post
Car: 2013 Genesis Coupe
Default 01-07-2019, 04:13 PM
Sounds like waste gate rattle
Default 01-07-2019, 04:56 PM
Thanks for the reply, If I put in a new charge pipe with hks bov would that fix it?
Default 01-07-2019, 05:08 PM
Lol your charge pipe has nothing to do with your turbo hardware. This is a WASTE GATE rattle
Default 01-07-2019, 05:38 PM
Sorry man this isy first turboed bmw I have no clue how they really work, so I would have to replace the waste gate?
Default 01-07-2019, 05:45 PM
Buddy, if you bought this car without doing any research you're in for a rude awakening. N54s have problems with hpfp, waste gate rattle, turbos, valve cover gasket issues, among other things. I'd suggest you go and research more about this car before just jumping on a forum and hoping someone to answer all your questions, if you're not mechanically inclined I hope you have deep pockets or just keep the car stock or buy an aftermarket warranty with the car so in case you have issues you'll get it fixed by someone without paying a ton of money. Otherwise these cars can handle power and make good power easily once you fix everything lol. Take some time to research.
Default 01-07-2019, 06:19 PM
I've actually done lots of research on the n54 and have done all mechanic work on my last BMW I already know the fragility of the engine and bought it for the rewards out way the cons. Ik the hpfp has problems and already made sure it was replaced prior coming from an e46 330ci I just am lacking knowledge on the turbo side of things.
Default 01-07-2019, 06:24 PM
The engine isn't the issue, it's everything around it. If you've done alot of research then you'd know already that most people have just replaced turbos, there is a recall but you're most likely out of that recall period, and know that JB4 has a setting to minimize that sound. Having mechanical experience also means you know how the fundamental engine works with and without a turbo.
Default 01-07-2019, 06:26 PM
I appreciate the feedback man but I'm not running JB4 it has a dinan s3 tune and now my BMW tool won't need codes on it rip
Default 01-07-2019, 06:29 PM
You do realize this forum is ran by the person who owns JB4 right? Lol... Get rid of that Dinan tune get a jb4 and flash an ots mhd tune from here, you'll enjoy life much more
Default 01-07-2019, 06:30 PM
Lmao I'll have too thank God I didn't pay for the tune, I ordered ngk plugs from Burger already
dusty dusty is offline
Default 01-08-2019, 05:39 AM
If the ticking noise was not when you bought the car and started after, i recommend you to change the vacuum lines.
Default 01-08-2019, 09:54 AM
This is misinformation, he's having hardware issue, he's not going to all of the sudden just need vacuum lines to cure his waste gate rattle LOL
Default 01-08-2019, 01:24 PM
Yeah idid more research and I think I'ma go for a twin upgrade while I'm at it and I pulled codes with my phone using obd2 to usb on the mhd app and am getting a cylinder 4 misfire aswell as a the battery seems to be dying so I'll have to get a new one and reset the system so the alternator won't mess it up. Thx for all the help again man I appreciate it.
Default 01-08-2019, 01:52 PM
Are you actually misfiring or do you have a stored misfire code? If you changed your plugs and you have the Delphi coils, then your culprit could be a leaky injector which does happen. You'll need to code the battery not just reset it as well. I also do not recommend a twins upgrade as alot of people tend to have issues with hybrids. Single turbo would be more of my recommendation but that's just my opinion. I'd line out all your issues first.
