steezyN55 steezyN55 is offline
Car: 2015 335i
Default first log ive done with the jb4 i wanted to get some feed back - 12-16-2018, 05:30 PM
freeway roll.csv 2015 335i with vrsf ******* ,bms intake and jb4 running map 2 on 91 pump
Default 12-16-2018, 06:54 PM
Looks good, but update to the latest v12 firmware and relog map2. Should be stronger.
Car: 2015 335i
Default 12-16-2018, 09:11 PM
How can I go about updating to v12 firmware I’m new to my jb4 so I’m still learning things about it everyday.
Car: 2015 335i
Default 12-16-2018, 09:12 PM
@terry, also can I run an e30 mix with the setup I have. I’ve looked online at what I needed to run an e mix and it said I needed some wire connector. Did the jb4 I purchased come with that connected in the wiring harness already?
Default 12-17-2018, 11:16 AM
Originally Posted by steezyN55
@terry, also can I run an e30 mix with the setup I have. Iíve looked online at what I needed to run an e mix and it said I needed some wire connector. Did the jb4 I purchased come with that connected in the wiring harness already?
https://www.n54tech.com/forums/showthread.php?t=18588
When did you purchase? Usually it should come with the fuel wires.
Car: 2015 335i
Default 12-17-2018, 11:52 AM
I purchased the jb4 with the data cable about 3 months ago or so and installed it as soon as I got it.
Car: 2015 335i
Default 12-17-2018, 07:06 PM
terry how do i know which firmware i currently have and also how do i know which firmware is the most up to date such as the v12
Default 12-20-2018, 11:31 AM
firmware version is located at top of log / CSV
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
