dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 340i Map 5 Dyno - 10-27-2018, 08:46 AM
Whatís up guys. Iím hitting up a local DynoJet today to see what kind of power my 2018 340i is putting to the ground. Any guesstimates? Iím hoping it hits at least 380whp. Iíll post up the graph and video in a few hours and hopefully the shop I called yesterday does not bail out.
Mods: BMS intake, JB4 map 5, CG 5Ē catt3d, and the MPE (I doubt adds any power). I also have 3 gallons of E85 in the tank topped off with a full tank of 91 octane gas.
|2018 BMW 340i|M-sport|Track Pack|
|M-Performance exhaust|VRSF|BMS intake|JB4|BMS Meth kit Dual BM7 nozzles|
jrdoming jrdoming is offline
Default 10-27-2018, 10:43 AM
Anxious to see this. I haven't been able to go above map 2 :/
2017 340i M Sport. JB4
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 10-27-2018, 11:08 AM
I'm going to guess under 400rwhp! Can you try dyno'ing in other maps too? Or do you need time for the ecu to get used to the map?
2016 340i M-Sport |JB4|ER DNPIPE|BMS Intake|
dRDiesel's Avatar
Car: BMW
Default 10-27-2018, 11:16 AM
393rwhp and 439 ft lbs
I’ll post up the graph and video I’m not happy with how the graph looks and the car couldn’t stop kicking down the gears.
dRDiesel's Avatar
Car: BMW
Default 10-27-2018, 11:45 AM
SAE graph and video is on Instagram
https://instagram.com/p/BpchsrtApAE/
Car: 2016 340i
Default 10-27-2018, 03:29 PM
What octane you running?
CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Default 10-27-2018, 04:09 PM
Did you get the car in ''Dyno Roller mode'' prior to doing the pulls ?
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BMS Billet Intake // BMS JB4 // BMS Pedal Tuner // BMS OCC // Dinan Free Flow Exhaust // Roof Rack // 365 days of fun
Default 10-27-2018, 05:11 PM
Is the e85 what is allowing you to get map 5? I'm *stuck* on map 2 with 93 octane. E85 isn't easily accessible for me sadly.
dRDiesel's Avatar
Car: BMW
Default 10-27-2018, 05:17 PM
Iím not sure it was in sport+ according to the dyno guy and it didnít cut off off on the rollers
dRDiesel's Avatar
Car: BMW
Default 10-27-2018, 05:18 PM
It most likely is letting me run map 5 the smallest dose does a miracle.
Car: 2016 340i
Default 10-30-2018, 09:34 AM
Are you planning on doing another dyno run? I think your the only person who did a map 5 dyno so far. Curious to what others dyno as well. Map 3 comparison would be nice too.
Default 10-30-2018, 01:01 PM
Looks like wheels bouncing on the dyno or something. JB4 logs of the runs?
dRDiesel's Avatar
Car: BMW
Default 10-30-2018, 01:28 PM
No logs totally forgot. I went to European Auto Source today and did another run and the graph looks way better and it hit best of 410rwhp.
https://youtu.be/RsyiPtEU7xg
Default 10-30-2018, 01:42 PM
Yes that's way more normal. Always log the runs with the JB4 though! Because what we really want to see is where boost, timing, and AFR are at those power levels to ensure it's well tuned.
dRDiesel's Avatar
Car: BMW
Default 10-30-2018, 02:04 PM
I know I was too distracted recording videos I wish I logged it. Should I get a street log and post it up so we can see if itís safe?
Default 10-30-2018, 02:39 PM
I'm sure it's fine, would just be interesting to see the log side buy side with the dyno. That's normally how it's done. The dyno is a tuning tool.
dRDiesel's Avatar
Car: BMW
Default 10-30-2018, 02:48 PM
Now itís either wait for the back-end flash or install meth or even install meth after the back-end flash.
Car: 2016 340i
Default 10-30-2018, 03:08 PM
Can you post map 5 logs? Possibly with the same fuel setup?
dRDiesel's Avatar
Car: BMW
Default 10-30-2018, 06:32 PM
Sure, I can get a log tonight
