(#76)
Default 01-19-2019, 05:39 PM
Right. I'd also set open loop to 30.
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 01-19-2019, 05:46 PM
Cool thanks for confirmation, I'll set open loop to 30 as well then.
Now, just need time & space somewhere to be able to grab some logs
Fame Douglas Fame Douglas is offline
Car: 2018 C63
Default 01-19-2019, 10:20 PM
Here are a few logs running maps 2 and 3.
Running a pump/race gas blend, around 96 octane.
Fuel Open Loop set to 20, per BMS.
Default 01-21-2019, 03:45 PM
Looks OK, let's shoot for some longer runs on map3 though!
Dat1racingchannel's Avatar
Dat1racingchannel Dat1racingchannel is offline
Car: AMG GTS
Default 01-21-2019, 09:19 PM
Hello Terry any idea when the direct Boost control module will be available? Also can a AEM (current setup) water/meth kit be connected to the Jb4?
Default 01-21-2019, 09:43 PM
On BCM no set date, we want to ensure the JB4 only cars are all running 100% first before we start raising the power up.
On WMI the JB4 works with any kit but we strongly suggest a kit with a flow sensor signal. I don't believe AEM offers that. We suggest a BMS kit which is prewired to work with the JB4.
BMW JB4 Methanol Injection Kit - Compatible with all N20, N54, N55, N63, S63 and S55 motors
Car: 2018 C63
Default 01-22-2019, 03:26 PM
Here's a longer pull in map 3.
I'm concerned about the AFRs and trims.
Default 01-23-2019, 09:48 AM
Both are fine for the short run. You can kick open loop up to 30 next.
Car: 2018 C63
Default 01-24-2019, 11:33 AM
Dumb question: I need to take my car to the dealer because the backup camera quit working. I’m temporarily removing the ODB port connection so they won’t notice anything. Will the JB4 function normally without it?
Default 01-24-2019, 12:09 PM
Dumb question: I need to take my car to the dealer because the backup camera quit working. Iím temporarily removing the ODB port connection so they wonít notice anything. Will the JB4 function normally without it?
Should be fine, just unplug it and check no big deal.
Car: AMG GTS
Default 01-27-2019, 06:55 PM
I’m having a issue with the Jb4 when I do two pulls the car goes into limp mode and I don’t have control over the transmission and there’s no boost pressure. When I Restart the car is goes back to normal. Any idea what it came be? It’s happen in Map 3 mostly.
Default 01-27-2019, 08:15 PM
Email in a log and details and we can help you sort it out. Could be a variety of things on the settings.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 01-29-2019, 07:58 PM
Here's a few logs taken today running Map 3.
Had a few runs & launches, no limp modes. Feedback - does it look right?
Default 01-29-2019, 08:20 PM
That interface looks to be an older one and is missing some of the tuning data. Using a hard wire cable and apple software I presume?
Looks like a lot of tire spin here! I'd go heavier on the boost reduction. Maybe 6psi in 1st and 4psi in 2nd.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 01-29-2019, 08:31 PM
Yes and yes - apple software with USB data cable. still had a bit of wheel spin, so I'll give the extra boost reduction a go.
If I can get a chance, I'll log with my windows software laptop <<-- is this how everyone else is logging at the moment?
Default 01-29-2019, 09:28 PM
Most are using the JB4 mobile adapter and their phone.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 01-29-2019, 10:40 PM
Ok thanks - might have to see if I can swing 2 here to make logging easier
Gbango Gbango is online now
Car: 16' C63s
Default 02-07-2019, 06:58 AM
What fuel are you using? On map 3, mine seems to require octane booster. Doing a mix of 93 and Torco and it runs great that way. Starting to seem like it's running out of breath up top. I suspect the intake is at or past it's flow limit.
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 02-07-2019, 01:30 PM
Not sure what the equivalent is overseas but here I only fill up on our 98 octane rated fuels:
Shell V-Power 98 | Shell Australia
Fuels, Vortex Premium, AdBlue | Caltex Australia
Running this fuel regardless of tune but it seems to have no issues with map 3 or 5 throughout the power curve so far. .
Default Yesterday, 05:03 PM
Jon put together a demo video of the C63 JB4 Mobile for you guys!
notabenex notabenex is offline
Car: MB W205 C250
Default Today, 12:08 AM
Great video. I am doing install in two weeks!
ezatnova ezatnova is offline
Car: 335i Coupe
Default Today, 05:04 AM
Thanks for the video.
Any chance of a nice detailed install video? Would be really helpful.
Also any general/stability/performance/etc updates? Realize it’s winter but it has been pretty quiet.
Hoping for a bunch of solid info on simple plug and play for stock S model on pump gas.
Exciting times!
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gbango
