oldmanjoe oldmanjoe is offline
Car: BMW M140i
Default Map 2 produces consistent hiss of air rather than exhaust note - 07-26-2018, 09:29 AM
Dear all,
I am not real knowledgeable but something isnt right here. When I select map 2 and really go for it, it produces a compressed air noise like the car is more air powered than actual exhaust. It sounds like a growing volume of air coming out of a garage tyre inflator.
When I go back to Map 1 its not so bad, almost none existent. I think maybe its overboosting? or the wastegate is open. Its going pretty hard mind you.
When I switched down to map 1 the hissing noise wasnt as apparent at all.
Other setttings - Ive tuned ASD to be a F87, Ive found it to be nice and quiet without giving me bull**** noise I dont necessarily want. Could it be that? I suppose first step would be to totally disable ASD and see what happens. But even the volkswagen I passed pulled and said theres something not right with it.
Any suggestions guys?
Default 07-26-2018, 09:40 AM
Would have to see the log for any tuning advice, but probably normal induction noises. If there was an issue, you'd get a CEL.
Car: BMW M140i
Default 07-26-2018, 10:32 AM
Very good point Terry. As for logs, well, does it have to be good ole American drag racing style pulls or can it be hard cornering up a mountain road...the later is possible. Former...would frighten the swiss cows here...as it is I will incur the wraith of angry cyclists doing it anyway.
Antec800 Antec800 is offline
Car: 340ix
Default 07-26-2018, 07:05 PM
I think because map 2 makes more boost compared to if you were on map 1 or 0
ParadigmDawg ParadigmDawg is offline
Car: X3M40i
Default 07-27-2018, 07:20 AM
You just need to put it in manual 3rd gear and run full out from 2,000 rpm to redline and then get off of it.
2018 X3M40i
JB4
BMS intake
