emmanuel.yoo emmanuel.yoo is offline
Car: X3M40i
Default B58S heatsoak and Jb4 - 07-07-2018, 10:04 PM
Hey guys, I have the x3m40i. Stock this engine is great considering itís powering a x3. When I added the jb4 and bms billet intake with 94 octane l, the first 2000 Miles it ran inconsistently. After that the shifts were smoother. I didnít feel a huge increase in power. I am running map 5. In assuming itís due to the stock b58s engine being tuned by Bmw already. With these mods I ran 12.3 on the 1/4 mile. I think I made this time because all the confitions were optimal and I had wind pushing me maybe lol. Usually I run 12.7-13.2 depending how hot is my car and the ambient temp/humidity.
Is there a way to prevent heat soaking with the b58? I mean, 12.3 to 13.1 is a huge discrepancy. Also will jb4 release an update to give more power to the mppk2 engines? I find the jb4 will help a normal b58 engine a lot more than the b58s mppk2.
Please let me know what mods can help with heat soaking...
Dj_quik Dj_quik is offline
Car: 2017 m240xi
Default 07-07-2018, 11:58 PM
Youll need to run meth injection and/or race gas
Bullitt1841's Avatar
Default 07-08-2018, 12:17 AM
You'd need to datalog to figure out why the car is inconsistent. There's no magic here.
2018 Audi RS3 | Stage 1 E85 and 91 Flashes | JB4 for Logging
Default 07-09-2018, 09:42 AM
Best way to determine what is going on would be to post a log for us in the support section.
ParadigmDawg ParadigmDawg is offline
Car: X3M40i
Default 07-10-2018, 02:20 PM
Don't help him, he is trying to outrun my X3...lol...
2018 X3M40i
JB4
BMS intake
Car: X3M40i
Default 07-23-2018, 09:19 PM
Haha hey nice to see you on this forum! Can't wait for some sort of radiator upgrade for the b58 and a ******** to become available for us!
Ok I'll post some 3rd gear pulls when I can get to a safe spot!
Mrpink Mrpink is offline
Car: M140i
Default 07-23-2018, 11:43 PM
https://www.wagner-tuning.uk/400001002.html
Car: X3M40i
Default 07-26-2018, 05:14 PM
Here is a 1st-2nd- a little bit of 3rd gear pull. Let me know what you think. I'm running map 6 at 17psi absolute. Is my timing okay? And how much can i boost safely with the b58?
BMW After BMW
Car: BMW M240i
Default 07-26-2018, 09:56 PM
Early on your AFR is mighty lean even for this motor - especially at redline. Maybe that’s normal at red but it’s reading in the 22:1 range. Yikes. Probably because it was 1st gear pull. Your 2nd/3rd gear pull had a brief nice run there and it appears you eventually hit your 17psi target but I wonder if you have the octane from seeing that timing curve. Someone with more experience can advise you better, but I would drop target to 16 and try some longer runs in 3rd, 3k to redline.
2017 F23/M240i Convertible (B58) / 6MT / FF Wires / EWG Wires / BMS Air Intake / Stock Exhaust / BMS Meth (50%) / 93 Octane
Default 07-26-2018, 10:27 PM
Log is too short to really see anything. That's why we recommend 3rd or 4th.
Car: X3M40i
Default 07-28-2018, 10:10 AM
Here is the 3rd gear log and a little of 4th gear.
Default 07-28-2018, 11:53 AM
Looks pretty good. How does it feel?
Car: X3M40i
Default 07-28-2018, 05:45 PM
Feels okay, I find map 5 is giving more torque tho. Should I try 18psi on a b58? I also have billet bms intake and 94 octane. Can anyone chime in to let me know how many psi stock b58 can take?
Default 07-28-2018, 06:19 PM
You'd have to compare logs of both, side by side.
What mods are you running? EWG or FF wires? Post that into your signature.
This engine can probably take well over 25 PSI, even more. We have barely begun to start pushing it.
Your boost all depends on the fuel you are running. You probably can't run more than 18 PSI without ethanol, race gas, or meth.
Car: X3M40i
Default 07-28-2018, 08:57 PM
I don’t have wires yet, is it worth it? I’ll try map 6 at 18 psi flat. I think my 94 octane uses 10% ethanol. I’m just scared to blow stock turbo @ 18psi.
Easy going foodie!
2018 X3m40i Untlimate package/merino leather/piano black trim
-JB4
-BMS billet intake
12.3 1/4 mile @108.88mph/7.8 1/8 mile
BMW After BMW
Car: BMW M240i
Default 07-29-2018, 01:48 PM
Smooth and sustained 18 psi is going to be hard without EWG wires and better fuel, in my experience. Almost all gas in the US uses 10% ethanol these days - but that's not enough to raise octane substantially. You need E85 (some, not too much), methanol, or race fuel...
Default 07-30-2018, 07:34 AM
^^ Correct
