Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default B58 duty bias adjustment - 06-06-2018, 08:01 PM
If I were to say zero out the default duty bias values what what exactly will that effect? Spool up time? Target boost? Thanks.
Default 06-06-2018, 09:03 PM
If you have EWG cable should change your duty cycle resolution. We usually have it at default 50 across all rpm with EWG cable.
Car: 540i G30
Default 06-07-2018, 04:05 AM
I do hve he EWG cable. The default show for the B58 are max of 30. So you say to put them all to 50? What exactly does that effect on?
carguy19 carguy19 is offline
Car: 335 cpe
Default 06-07-2018, 11:10 AM
I am interested in knowing as well. Mine has been setup ramping up at low rpm from 15 to 30.
I do have a EWG harness as well.
What will setting it at 50 do? Will it help the control of the WG?
Car: 540i G30
Default 06-07-2018, 11:42 AM
Can terry or someone please chime in.... thanks.
Default 06-07-2018, 01:15 PM
Leave it at default values. I was looking at a different tab when giving you the values.
http://www.n54tech.com/forums/showthread.php?t=31429
Car: 540i G30
Default 06-07-2018, 01:23 PM
So those values stay the same with or without EWG wires....?
Default 06-07-2018, 01:48 PM
Without the EWG wires, those values mean nothing.
