emmanuel.yoo emmanuel.yoo is offline
Car: X3M40i
Default X3M40i: Bog and throttle closes randomly - 05-10-2018, 09:42 AM
Hello, I just got the JB4 for the B58 for my X3m40i. I used to run MHD on my N55 135i and I decided to make the switch to BMS for the B58 because I appreciate all the support Terry is giving reading out our logs! Love the Bluetooth feature and the quick map changes.
My car is fully stock on 94 octane gas. When I run Map 1 I feel no change. On map 2 I feel a little more power. I tried Map 3 and there is a major engine bog, I don't really know how to read the logs but I do see my throttle closes a little on 100% pedal. I also tried map 5 and it's smoother than map 3 but still, I get issues with the throttle. On map 6 at 17 psi flat boost it's not soo bad but on the logs I still see the throttle closing.
I attached the logs in csv. Hope someone or Terry can help me out here! I'm waiting for the BMS intake to arrive also. There is so many parameters I do not fully comprehend.
I attached 4 map 6 at 17psi flat boost logs and one on map 2. Hope I logged well enough... it's my first time logging! Let me know if you see something I should change in the parameters! Also thanks in advance!
High Flier's Avatar
High Flier High Flier is offline
Car: 340iX 6MT MPPSK
Default 05-10-2018, 10:32 AM
Try posting in the BMS Support Request forum. You may find this helpful in reading parameters: http://www.n54tech.com/forums/showthread.php?t=21269
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 05-13-2018, 10:07 PM
Salut Emannuelle. Je vois que tu change tes vitesse tres haut...6700-6800 rpm. As tu teste a 6000 rpm?
Mon x3 je change a 5500 rpm (n55) Mais je crois que ton b58...6000.
On se revoient a St-Eustache ou Icar
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL **|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
Car: X3M40i
Default 05-20-2018, 09:44 AM
Salut BobVader! Oui la B58 shift vers 6000rpm. Je vais essayer de voir pourquoi mon throttle ferme aléatoirement durent les shifts. J’irais à icar ce jeudi si la température nous le permet!
BobVader's Avatar
Car: 335xi 2008
Default 05-20-2018, 02:10 PM
Moi aussi jeudi. As-tu un ******** sur ton x3. Parait que le b58 n’aime pas ca.
