Originally Posted by PrzeChuj
Your car has a vacuum line running from the engine bay on driver side to the real on the driver side. It is what controlls the exhaust fume flap o, factory exhaust. The vacuum in that system is not connected to ur manifold pressure but to a vacuum pump .
U disconnect it under,the hood and cap of the end going to thd engine so u dont suck anything in the vacuum pump and damage it. I then connected the line with a tee fitting to the hose for my,blowoff valve which is easiest . on the opposite end behind driver,side,tail light u have a acctuator that controlled the exhaust flap. I'm running aftermarket exhaust so it has been disconnected,long ago. I pulled the hose,off that comes from the engine bay and not the one going down to exhaust. That hose is where my hobbs switch is connected. I used the red wire from the connector from the actuator to connect to one terminal on hobbs switch. The wire is only powered up with ignition on so it gives u a safety feature. The other terminal of hobbs switch is ran to my rely I have by the battery and activates,the relay at desired psi. I have battery positive from the battery ofcourse ran to a fuse and into the relay and then to the pump.
If you want I can take some pictures and draw u a simple schematic to make it easier for u to understand. Instead of paying for the wiring harness.
Aah thanks for the explanation!
I have the stock exhaust, but i assume it woulde still be fine to remove that vacum line or what does that feature do?
