Shorty Shorty is offline
Car: BMW M140
Default Map 6 for people running meth. - 10-02-2017, 02:07 AM
Hey lads.
Has anyone had a play with map 6 yet and running meth?
I've read somewhere that there's no meth safeties for map 6? I take it this means if the JB4 sees the meth flow goes it will not pull boost back like it does in map 7?
How hard would this be to write in? Hopefully Terry can chime in with his thoughts.
Has anyone tried it anyway? And just kept an eye on the meth flow.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 10-02-2017, 02:46 AM
http://www.n54tech.com/forums/showthread.php?t=22272
VTT Stage 2+ turbos, BMS JB4, EOS PI with BMS controller, RB Inlets and Outlets, VRSF CP and Intercooler. Tial bov, miltek exhaust. Tuned by Trebila.
11.3@127 (https://www.shakespearecountyraceway.co.uk)
Car: BMW M140
Default 10-02-2017, 04:22 AM
Originally Posted by Russjonesr
Will this work on B58 JB4 aswell?
I know meth trigger mode works, as sometimes I have meth on while running say map 3. But what about meth safety?
Car: BMW M140
Default 10-02-2017, 06:23 AM
Will try meth safety at 1 or 2 and see how it goes.
Wickedowesix's Avatar
Wickedowesix Wickedowesix is offline
Car: 540i G30
Default 04-30-2018, 07:23 PM
So did you like meth on map 6 or map 7?
Car: 540i G30
Default 06-01-2018, 05:01 PM
Anyone running map 6 with meth?
Mrpink Mrpink is offline
Car: M140i
Default 06-18-2018, 01:10 AM
Been trying it this weekend.
Fastest times for me are still map 7 but with 35 add
herbchemist herbchemist is offline
Car: 2010 Dinan S3 E93/N54
Default 06-19-2018, 04:26 PM
My custom BEF was created by Trebila. He set me up with Map 6 w/ E50 + Meth (80%). I've been running it since Christmas and am quite happy. I'm set up as follows:
Meth Trigger - 0
Meth Safe Mode - 2
Meth Add (Boost Additive) - 75 ( don't believe this is active on map 6)
Meth Scale (Signal Scaling)- 40
Meth PSI (Min Flow Boost) - 8
I'm actually trolling the site today trying to figure out if my Min Flow Boost is too low. Perhaps I'm swamping too much meth at a low RPM. I'm boosting to 26psi and the 8 psi trigger is fireing at 3000 rpm (with dual CM10's)
2010 335i 'vert (E93) | Pure Stage 2 Hi-Flow | BMS FSB Meth w/ dual CM10 (80% Meth) | Inlets (MMP) | Outlets (PSP) | LPFP (Stage 2 Bucketless) | 6AT w/ xHP S3 | BMS DCI | FMIC (PSP 750ic) | High Capacity Oil Cooler | Dinan High Flow Exhaust | D*P* | ER CP | Synchronic BOV | RB PCV | BMS OCC | NGK 5992 @ 0.021" | | JB4 G5_ISO_32_8_T11 | Trebila BEF | Koni Suspension | Michelin P4S | Milage: 61k | Elevation: 5000 ft / 1524 meters
Default 06-20-2018, 07:21 AM
I'd stick with map 7 and just raise additive if you want to go higher. Just make sure the logs look good before doing so. I wouldn't use map 6 unless you know what you're doing and looking for when dialing things in.
If you're not sure, just post a log in the support section with details of your car and mods etc. We'll do our best to help you out.
Asuna's Avatar
Asuna Asuna is offline
Car: M240i
Default 06-22-2018, 06:40 PM
Meth Trigger - 0
Meth Safe Mode - 2
Could you tell me what is the mean of Meth safety mode 0,1,2,3?
Default 06-26-2018, 02:03 PM
*Meth Safety Mode All Versions
0 - Raise boost on map3 as a function of meth flow & historic timing (default)
1 - Raise boost on map3 as a function of meth flow only
2 - Start at normal target and failsafe IF flow drops below flow level for 1 second under boost. Enabled for all maps.
3 - When on map3 meth flow is completely ignored. Useful for using map3 as an adjustable non-meth map.
4 - Run a progressive meth safety on all maps
Asuna's Avatar
Car: M240i
Default Thank you - 06-28-2018, 06:27 PM
My engine is B58, I think your map 3 is my map 7.
