(#176)
Default 07-29-2017, 08:53 AM
Originally Posted by dror135
after iso t7_6
i allways get error
180001 ******* ******** detecet
i delete it but its back after few hour
Then reinstall your factory equipment or if outside the USA select passive delete on the WMI page to clear all codes at startup.
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 07-29-2017, 10:43 AM
Where is the CSV log you want me to look at?
Page 6...it happened all night last night. 3rd gear hits 21 holds 20 for a bit then slowly drops. Shift into 4th and it never goes over 13-14. Shift into 5th then its back up to 20.
2013 335i sportline pwg 8at~jb4 iso~e40~bms oil cooler valve~bms intake~wagner c-less~ap catback~phoenix ic~gfb dv+~pure inlet pipe~er tic pipe~vrsf cp~ngk's @ .022~h&r super sports~437m
kevinvachon kevinvachon is offline
Car: 2013 bmw 335ix
Default Check engine Error code after to install firmware N55_FSERIES_OBDII_ISO_7_T6.hex - 07-29-2017, 11:36 AM
Apres installation du firmware N55_FSERIES_OBDII_ISO_7_T6.hex ,
J'ai eu un check engine avec plusieurs code error:
120408 reduced power mode, 121001 tmap sensor , short circuit b+, 119001 rail sensor short circuit +, 104410 amp sensor intake pipe electrical short circuit b+.
Avant installation du firmware j'avais aucun probleme. Comment uis-je regler le probleme? Merci de votre aide
BMW 335ix 2013 avec le PWG
Car: 2013 bmw 335ix
Default Check engine Error code after to install firmware N55_FSERIES_OBDII_ISO_7_T6.hex - 07-29-2017, 11:37 AM
After installing the firmware N55_FSERIES_OBDII_ISO_7_T6.hex,
I had a check engine with several error codes:
120408 reduced power mode, 121001 tmap sensor, short circuit b +, 119001 track sensor short circuit +, 104410 amp.
Before installing the firmware I had no problems. How do I fix the problem? Thank you for your help
BMW 335ix 2013 with the PWG
Default 07-29-2017, 04:01 PM
Just seen that i got last safety 5 last night
Default 07-29-2017, 05:22 PM
If ignition was turned on with JB4 missing firmware you'd get those faults. If you can't clear them then something is wired, loaded, or set wrong.
Car: 2013 bmw 335ix
Default 07-29-2017, 05:56 PM
What are the solutions or steps to solve this problem, thanks for your help
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 07-31-2017, 05:07 AM
Originally Posted by 911Y4
Hi Terry,
Thank you very much for your quick response. Here is a new log (same fuel E45, same boost and same port injection) (BMS PI controller)
I set all AFR bias to 70 instead of 50 for more fuel, you can see the trim goes to negative, but fuel pressure still drops after gear shift (4th to 5th) and car went to open loop and trim was stuck at 25 after gear shifted
Could you please help, thank you for your advice!
Li Wang
Did you solve this problem? I have exact same problem with latest N55 ewg firmware.
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
Default 07-31-2017, 05:59 AM
A lot of us are having the trim problem. I assume they are working on a fix.
Default 07-31-2017, 08:55 AM
Depends why you're getting them in the first place. If everything is installed and working normally, there won't be any sensor related faults.
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 08-01-2017, 03:02 AM
I have got this in another firmware revision 7_T# something, I can't remember.
Yesterday I was putting in sport oil valve from bms and after fitting it they all came up, Yes I know there is no relation between them,
the engine wasn't idling well too. But after disconnect and connect battery there were no codes. and engine ran smooth.
N55 - Doc race 6266.
911Y4's Avatar
911Y4 911Y4 is offline
Car: 435
Default 08-02-2017, 01:15 AM
I have same issues, especially if car sits in hot and wet conditions, if I start the car, I will have these errors
BMW F30 335xi PWG N55 1/4mile 11.111ET @ 126mph
BMS JB4 ISO / PTF Bootmod3 / Pure N55 stg2 Turbo / Fuel-it PI + stg2 LPFP/ Wagner EVO 2 Competition FMIC / E30 + Meth
In Shanghai
Default 08-04-2017, 10:04 AM
Any word on why trims are staying so low?
afranke afranke is offline
Car: 2013 ActiveHybrid 3
Default 08-04-2017, 03:30 PM
Those MAP sensor codes happen when you plug/unplug stuff without disconnecting the battery and fry the ground for the TMAP sensor (at least it did for me). I fixed it using the steps on the last page of the install guide: http://www.burgertuning.com/instruct...4_f_series.pdf
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 08-05-2017, 03:29 AM
No, I didn't' touch anything I always disconnect my battery, but this time I was just installing sport oil valve. I think my battery is a bit low. gonna take the long roads from now on.
jcewing23's Avatar
jcewing23 jcewing23 is offline
Car: 2012 335 sedan F30 N55
Default Log help - 08-06-2017, 05:28 AM
Please take a look a my logs and adjustments I've made...am I runnin to lean...I'd really like a smoother throttle closure line...what can I do?
Default 08-06-2017, 09:38 AM
AFR is fine here and you can't change it anyway.
For throttle you'd have to work on duty bias tuning, but we might make the spool mode PWM setting user adjustable at some point to help with tip in overshoot.
Default 08-06-2017, 09:57 AM
What about the low trims?
Default 08-06-2017, 10:12 AM
Fuel trims are only a concern if under 0 or over 50.
Default 08-06-2017, 10:31 AM
Mine have been under 25 4500-up. I even had a last safety 5.
Default 08-06-2017, 10:33 AM
If its stuck at 25, that is a problem, since DME is in open loop. This is programmed during spool but if it stays there JB4 will failsafe.
Under 25 is fine and over 25 is fine. Range is 0-50.
Default 08-06-2017, 10:39 AM
Its not getting stuck but but should i raise fol since im running more boost on iso? Well more boost at peak but not up top. What is last safety 5?
Default 08-06-2017, 10:45 AM
Safety=5=fuel trims stuck at 25 (open loop mode).
Open loop should not be set above 70 or you may throw false fuel pressure faults at full throttle.
Default 08-06-2017, 10:48 AM
Well **** i been using 75 & 80
Default 08-06-2017, 10:51 AM
If no codes it's fine but expect fuel pressure codes eventually.
