(#2526)
TorchikRS TorchikRS is offline
Car: 2016 Infiniti Q50 RS400
Default 04-05-2018, 09:28 PM
Just a can with a full tank, I prefer the NOS race formula. Boostane and Torco are also good options but more expensive.
Sounds good, thanks!
Austen_vr Austen_vr is offline
Car: Q50 sport
Default 04-06-2018, 07:42 PM
I am having a terrible time trying to connect my Jb4 to my laptop. I have tried 2 different comps neither will connect. I have double checked the ports and the connection to the jb4. However, it always fails. I did notice i don't have a status bar athe bottom of the application. I downloaded the generic interface that is on the link. Anyone have this issue? Anyway to solve it?
Default 04-06-2018, 08:11 PM
Maybe a faulty cable, or 2580 chipset on the JB4 board? It's possible to static zap either. If you're sure the com port is setup right (drivers installed), and it's still not connecting, email us and lets try a new data cable.
Default 04-06-2018, 09:06 PM
Fellow red sport owners, if you run/ ran an e85 mix could you post some map 6 settings? Thanks in advance
Car: Q50 sport
Default 04-07-2018, 05:17 AM
Email sent, the stage 1 tune makes great power but there seems to be a lot of hesitation and choppy acceleration. Hope the updates fix these issues.
ThreeBlockWar ThreeBlockWar is offline
Car: 2017 Infiniti Q50 Red Sport
Default 04-09-2018, 11:10 AM
Make sure that you have the cable plugged into the OBD II port.
Car: Q50 sport
Default 04-09-2018, 11:37 AM
I put an exhaust on yesterday and messed with the obd2 plug. I guess it wasn't hooked up to the right plugs. all fixed.
LsRamAir LsRamAir is offline
Car: '18 Q50 RS AWD
Default 04-10-2018, 06:34 AM
Can someone speculate the similarities of 100 octane unleaded race gas (VP100 or Trick 100 from local pumps) and E85 in relation to the fuel reqs listed on page 1 of this thread?
Im thinking that to achieve an "E30" mix in a full tank would need more like 65/35 of 100/91 since the octane of ethanol is so high. OR, would I need straight 100 octane? (getting mighty expensive here!)
...trying to see how much 100 i need vs CA 91 in a full tank to be able to safely run (attempt and log) the 6psi maps on a RS.
2018 Q50 RS400 AWD (w/Sport Mufflers)
Loving the ride...
Infiniti Addict Infiniti Addict is offline
Car: 2016 RS400 AWD
Default 04-11-2018, 07:10 PM
You should be able to use the ethanol calculator to figure out your mix. But you will need to test any E85 that you use to see the actual ethanol content since it varies so much between stations and seasons.
http://www.wallaceracing.com/ethanol-mix-calc.php
jrobohm's Avatar
jrobohm jrobohm is offline
Default 04-11-2018, 07:27 PM
This calculator is very nice - thanks for sharing! Although we all need to factor in the residual fuel in the tank when filling up, this will help take out some of the guess work. Now it’s time to keep an ethanol tester handy to see what Valero’s E85 actually has in it. Any suggestions on easy to use / store testing models ?
slimjim2525 slimjim2525 is offline
Car: 2016 Infiniti Q50 Red Sport
Default 04-12-2018, 07:01 PM
Quick question. I have the JB4 on map 6, with a max of +4 at 3k-5500 rpm then tapers down. But when I hooked it to my computer tonight I noticed the boost safety was at 3.0. Does this mean I am not going to go over 3, even though its set at 4, and I need to increase the boost safety? Or will it go to +4 like I have it programmed? Thanks.
jrobohm's Avatar
Default 04-12-2018, 08:03 PM
Check post #2 for more details on JB4 Maps.
JB4 Maps:
Map0 - JB4 disabled
Map1 - 4psi peak
Map2 - 5psi peak
Map3 - User Adjustable fixed boost map (similar to Stage1) where “boost safety”
setting on the user adjustment page determines boost added across the power band
Map4 - Stock boost with CANbus active for data logging
Map5 - 6psi peak
Map6 - User adjustable by RPM map using settings on user adjustment page. A
setting of 5.0 would request 5psi over stock at that specific engine speed.
Map7 - 7psi peak
Default 04-13-2018, 04:12 AM
I know that. My question is do I need to change the Boost safety to match the amount of boost that I programmed?
jrobohm's Avatar
Default 04-13-2018, 05:24 AM
Roger that - with a JB4 when Map6 is selected, the Boost Safety Value is ignored in favor of the user adjustable boost by RPM settings. The Boost Safety Value only comes into play if you select Map3.
Default 04-13-2018, 06:56 AM
Okay got it thank you.
Car: '18 Q50 RS AWD
Default 04-16-2018, 09:07 AM
First off: Thank you for developing the JB4... Amazing part!
FEATURE REQUEST:
Allow renaming of the map slots in Android app.
...wait, you arent the dev... doh! Sorry.
Please accept our thanks and keep up the good work.
Loving the ride...
Default 04-16-2018, 09:08 AM
+1
FEATURE REQUEST:
Donnie does the app development for us. What do you mean naming of map slots?
Car: '18 Q50 RS AWD
Default 04-16-2018, 10:22 AM
Like instead of just Map1, map2 etc...
I could overwrite with 4psi, 5psi, Custom 3,4,5,6,5,4 psi, stock, etc.
My memory gets a lil iffy for which is which when I'm changing fuels often and choosing slots wisely. The wife doesn't remember which is which either when she goes to get gas and has no torco or race fuel nearby.
Sorry if it sounds so minimal. Just a nice aesthetic to have a label. First world problems! Thanks.
Loving the ride...
g0t2bmiirii's Avatar
Default 04-16-2018, 09:29 PM
Terry, does the Q50 have anymore room for performance on the jb4? Like more possible boost?? More mods with the jb4?
-D0WNP!PES + Catback[resonated]
-BMS Cold Air Intake
-JB4 (map 6) w/Fuel Wires (93oct)
Default 04-18-2018, 01:35 AM
If someone can post their Red Sport map 6 set up with e30 that would be great!
Thanks in advance
2016 RS400 AWD
BMS Intakes
JB4
Infiniti Sport Exhaust
Esco Esco is offline
Default 04-18-2018, 04:52 AM
Thanks in advance
2016 RS400 AWD
BMS Intakes
JB4
Hopefully that worked.
This with e30, jb4, bms intake, stillen ***-back
Default 04-19-2018, 12:37 AM
Thanks! Just a side note, is there a reason you didnt go +6?
UAMACH1 UAMACH1 is offline
Car: Q50 RS
Default 04-19-2018, 11:07 AM
I'm personally debating JB1 v JB4 right now. Not planning to do any custom tuning, just use it as a "set it and forget it".
I assume that both JB1 and JB4 will both only give my RedSport +3PSI. I have seen mentioned that the JB4 without the laptop/BT adapter is basically JB1 but "smoother". Has this been shown on a dyno? Or just in logging? Is JB4 worth the extra $100 over JB1 just for the "smoothness"?
Default 04-19-2018, 12:40 PM
It's easy to start with the JB1 then upgrade to the JB4 later if you decide you want more than the JB1 offers.
