Go Back   N54Tech.com - International Turbo Racing Discussion > General > DIY Modification
Reload this Page Repairing damaged 2013 2014 F Series ECU DME TMAP ground trace
harkes harkes is offline
Registered Users
Car: M135i
Default Repairing damaged 2013 2014 F Series ECU DME TMAP ground trace - 06-20-2015, 02:26 AM
Hi guys
A while ago I was unlucky to damage my ECU by letting the USB get in contact with the 12v rail. This burned the TMAP ground trace in the ECU, which meant that the TMAP sensor did not work and that I got P0238 and P007D. BMS/Terry know about this issue and there is a "quick fix" solution on the last page of the F30 install manual (PDF).
That solution is not good enough for me though, so today I got my ECU repaired so I no longer have to jumper the TMAP ground. BMW will replace your ECU if this happens to you and hand you a +2000usd bill (thats what I heard). It cost me 60usd to have it repaired + my own labor removing/installing the ECU (http://f20.1addicts.com/forums/showthread.php?t=1123651).
Registered Users
Car: M135i
Default 06-20-2015, 02:27 AM
Column 2 - pin 8
Default 06-20-2015, 08:38 AM
vibes81's Avatar
vibes81 vibes81 is offline
Car: bmw m135i
Default 10-28-2015, 09:57 AM
Originally Posted by harkes
Hi guys
A while ago I was unlucky to damage my ECU which meant that the TMAP sensor did not work. Luckily BMS/Terry know about this issue so he had a fix for it.
Today I got my ECU repaired so I no longer have to jumper the TMAP ground. BMW will replace your ECU if this happens to you and hand you a +2000usd bill (thats what I heard). It cost me 60usd to have it repaired + my own labor removing/installing the ECU (http://f20.1addicts.com/forums/showthread.php?t=1123651).
Hi there,
Thanks for sharing this useful information. Am also communicating with Terry on this to fix this issue. A question I have is it oil/grease we see on the dme board? Similarly, mine has oils as well? Could you advise if it's normal? Thank you in advance. Best regards.
Registered Users
Car: M135i
Default 10-28-2015, 04:38 PM
No I believe that is some sort of wax or soldering flux - normal. You also got unlucky with your USB cable?
mrjcover mrjcover is offline
Car: E92 N55
Default 03-30-2016, 02:55 PM
Column 2 - pin 8
What kind of shop did you take it to to get repaired???
Registered Users
Car: M135i
Default 04-26-2016, 10:15 PM
I place that specialize in fixing flood damaged car electronics - yes, we have that in China
SocalF3255 SocalF3255 is offline
Car: 435i
Default 01-18-2019, 05:32 PM
Any electronics repair shop that is familiar with board level component repair should be able to knock this out for less than an hours labor. I've done this exact repair for Porsche as well as BMW ECU's. I would not attempt this as a DIY soldering project as you can easily ruin more than board traces if you are not careful with ESD and heat. The BMS work around is more than adequate otherwise.
